hoghead Posted May 6, 2010 #1 Posted May 6, 2010 I'm going to be in the area around the middle of May. I like the size and the look of this sidecar. Problem would be is there any way it could/would work on a RSV? I know so little and want one so bad. hh http://phoenix.craigslist.org/wvl/mcy/1700009499.html
Eck Posted May 6, 2010 #2 Posted May 6, 2010 Any thing can be attached to a Venture.. All depends on the persons inginuity...and how bad he wants it.... Yes, it can be attached. You may need to design and manufacture attach bars /brackets to make it happen..
RedRaptor22 Posted May 6, 2010 #3 Posted May 6, 2010 If my research is correct for that particular side car to be attatched to the venture you will need a welding machine, side grinder and 12pack.
hoghead Posted May 7, 2010 Author #4 Posted May 7, 2010 If my research is correct for that particular side car to be attatched to the venture you will need a welding machine, side grinder and 12pack. I have the beer. hh
hoghead Posted May 7, 2010 Author #5 Posted May 7, 2010 Any thing can be attached to a Venture.. All depends on the persons inginuity...and how bad he wants it.... Yes, it can be attached. You may need to design and manufacture attach bars /brackets to make it happen.. Dang..it looks like the right size. Oh boy. hh
SteveW Posted May 7, 2010 #6 Posted May 7, 2010 There is no reason why it would not work. You have the 4 attaching points and can make up mounting brackets. I even made a trailer setup for mine so I can take the slidein camper, truck and bike at the same time.
Aussie Annie Posted May 7, 2010 #7 Posted May 7, 2010 And this is what mine used to look like. It's now on a Harly.
