It's finally done and back together.
dingy
My re born 83 had its coming out party today. It is finally all back together.
There are parts from 3 different decades on this bike.
It will be a different color next spring. Probably a bright blue or yellow.
Thanks to everyone that contributed knowledge and parts to get this done.
Below is a list of the major improvements this winter and a few pictures of it.
1300 engine, 1988, 28,000 miles
Vmax Heads, 1997, 19,000 miles
FJR rear end, 2004, 7,000 miles
MKII front forks, 1986
MKII brake calipers & rotors - front & rear
MKII brake master cylinders - rebuilt
Delinked brakes
Stainless steel brake lines
Speed bleeders
Kevlar brake pads
Electric Anti Dives – only operate on front brake
Rebuilt clutch master & slave cylinders
Stainless steel clutch line set
Two diaphragm springs in clutch
Replaced half clutch plate with full plate
Starter ground upgrade
8mm ignition wires
Iridium spark plugs
K&N air filter
Crankcase air breather filter
Re-jetted mains to 140
Shimmed needle jets to .072”
Updated rear shock to one with spring
Grease fittings added to shock linkage
Halogen Dual Projector Headlights
Added tail light bulbs to rear turn signals
Cruise control
Class system
Royale instrument cluster
1988 wiring harness
Changed radio to AM/FM CD player
3 way speakers in front -Tweeters in saddle bags
Shorty antenna
Relocated TCI to radio compartment
Radar detector & GPS mounts
Bikini side covers
Polished case covers
S.S. bolt set for side covers
Passenger foot boards
Moved backrest rearward 2”
Powder coating
Pictures today.
Started out as this.
Went down to this.
Donor of lower engine and brakes.
Edited by Freebird
Added engine close up
How does it run?
Do you like the de-linked brakes better?
I de-linked mine and have not rode it yet . . .
It has a LOT more acceleration. I can pop the front end up fairly easy now. Red line is now close to 9000 RPM's.
Seems like I need to upshift when I am in 5th though due to FJR rear end, it will take a little getting used to the higher cruising RPM's.
As far as the brakes, I am happy at this point. The rear will not lock up on me which is good in my opinion. The fronts will lock up, which could not be good, but will be same as bikes I have always rode.
I also made a revision inside of the wiring harness to keep the electric anti dives from engaging when only the rear brake is used. I have heard the electric A/D's are energy hogs. Didn't figure I needed them when I was only using rear braking. This way, if I am in traffic, I can use the rear brake and not have the drain on the electrical system.
Gary
Hey Gary,
Great Job! Glad to hear you got it all back together! I bet she's a runner! As far as the front brakes locking up goes, try backing off on the air pressure a few pounds, the slight bit of tire flex will keep the brakes from locking up the front tire. Great Idea, disconnecting the anti-dives to the rear brakes.
I hope to see your bike at Maint. Day,:thumbsup2:
Earl
Outstanding Job Gary !!!
Congrats on your fresh Ride, i'd love to ride around with you sometimes and see what's in there now !!
:thumbsup2::thumbsup2::thumbsup2::thumbsup2:
Disclaimer:
If someone's sensing the Enviousness between the Lines, that's the Truth, the whole Truth and nothing but the Truth :whistling::whistling::whistling:
Gary
I'm jealous.
Let us know what kind of MPGs it gets.
BTW: Good Job :clap2:
I like it alot...except for the bright red stuff, I don't care much for that. All the rest is kewl tho.
DITTO on this ... it really clashes whith the color of the bike... but maybe you have plans to repaint a different color? Not sure what will go with those RED accented parts tho.
That's a LOT of work you did... :thumbsup2: :thumbsup2:
You mentioned that you were going to paint it bright blue or yellow.
My vote would be for the bright yellow. I like the way yellow and red go together, add a couple of black pinstripes to match the engine color and you have it made.
Cant wait for next spring to see the new colors.
  • 2 weeks later...
I got my beast running (Vmax cams and springs in 1300). I have the stock 1200 (1985) carbs on it at this time. The carbs have new diaphragms and have been cleaned within an inch of their life. Although it starts and idles great, when I blip the throttle it hangs before returning to idle. This appears to be a lean condition.
How did you decide on 140 main jets? (stock is 117.5)
Why did you also add spacers to your needles?
