Guest motohead
I have a 89 VR and on Friday it started idling VERY fast.It now is idling at or above 3,000rpm's.I checked and lubed the throttle cables and replaced to the fuel filter and it did nothing.I also sprayed carb cleaner on the intake boots and it did NOTHING.This all started all of a sudden.It was idling at about 1,000rpm's and the next time I pulled in the clutch it to 3,000 and has been there ever since.ANY ideas ?????
If the choke is not stuck, and the cables are all working fine, try seafoam.
Had a similar problem and it went away after a few tank fulls of gas and seafoam.
Brad
Mike Junes had the same problem at VWIII. Started on the way to Sue-ville. I can't remenber what all the 'wrenches' finally found to correct the problem, but maybe one of them will chime in here with words of wisdom...
  • 6 months later...
