awsmsrv Posted October 16, 2007 Posted October 16, 2007 Last time I did this, I used a Tupperware container that almost overflowed by the time all the oil drained. I'm looking for something that will fit under my Sears bike lift, maybe 12"L x 10"W x 6"D. Any suggestion are greatly appreciated. Thanks.
bill p Posted October 16, 2007 Posted October 16, 2007 Any auto parts store sells drain catcher containers. They are worth the one time investment. They are either round or rectangle and have a side drain with a cap. They work fine. Bill P
rod Posted October 16, 2007 Posted October 16, 2007 I have lined a cardboard box with a trash bag and it worked good. I have an oil pan that fits under the bike and I just slide it under the bike and change the oil without the lift. Rod
dray Posted October 16, 2007 Posted October 16, 2007 i don't use a jack i leave my bike setting on the ground and change my oil i use a plastic garbage can lid it catches all the oil with no problem havent had a spill yet and lots of room in it for the oil:smile5:
bongobobny Posted October 16, 2007 Posted October 16, 2007 Ditto! No lift, and use a drain pan I ve had for years from K'Mart and use it on my cages as well.
Paul Posted October 16, 2007 Posted October 16, 2007 I use an old roaster of the wifes slides under perfect with it on the center stand. From there I dump it into the coal bin and then to the furnace. Paul
Kurt Posted October 16, 2007 Posted October 16, 2007 I put the bike on the center stand and drain into the same pan I use for everything. If you use the lift and have trouble getting the pan under you might try another trick I use sometimes. On my snowblower the drain pipe came out over the space between the wheel and frame. I would just cut a piece of cardboard and bend it into a v and use that as a trough to get the drain oil to the pan. Just pitch the cardboard when done. If the trough method works you could get some light aluminum and bend a more permanent one. The snowblower was a once a year thing.
Thom Posted October 16, 2007 Posted October 16, 2007 somebody here makes a bracket that gos on your jack , after you jack the bike up , put on the 4 legs and remove the jack , kewl huh , but he is bias , he don't like 1Gs because he won't make us one :rotfl::rotfl:
Vance Posted October 16, 2007 Posted October 16, 2007 somebody here makes a bracket that gos on your jack , after you jack the bike up , put on the 4 legs and remove the jack , kewl huh , I think thom440 is referring to Carbon One's lift adaptor, with the leg attachment.
KiteSquid Posted October 16, 2007 Posted October 16, 2007 I use a Rubbermaid Draintainer that sadly is no longer made... On my 1950 H-D FL to remove the oil filter, I cut an empty 1.5 L plastic Gin Bottle (IIRC it is Miltary Special brand) to fit behind and around the filter, to catch all the oil.... Modifying plastic bottles from the trash works for me.
pegscraper Posted October 16, 2007 Posted October 16, 2007 No lift. An old oval shaped pale green granite pan is what I use. It lasts. I find that any of the plastic ones warp and crack after a while.
SilvrT Posted October 16, 2007 Posted October 16, 2007 I use a round drain pan I got at Canadian Tire years and years ago. It's about 4" deep and has a "V" lip on one side for pouring the old oil out. Disposing of the old oil is a bit of a problem tho because you just can't dump it anywhere.
Guest shotgunridergirl Posted October 16, 2007 Posted October 16, 2007 no lift, an old cat litter box
kantornado Posted October 16, 2007 Posted October 16, 2007 I use a rubbermaid dish pan its blue in color and is the size your looking for. don't remember the cost but am sure it was cheep. Then I drain the oil into old gallon jugs for transport to the waist disposal area. put my old filter in the box from the new filter(after draining it and wiping it off) to take to the waist disposal area. Hope this helps...........................Ron
royalstarjac Posted October 16, 2007 Posted October 16, 2007 The nearest storm drain. Haaahaaaahaa!:rotf::rotf: Just kidding!-Jack
SilvrT Posted October 16, 2007 Posted October 16, 2007 The nearest storm drain. Haaahaaaahaa!:rotf::rotf: Just kidding!-Jack ssshhhhhhhhhhhhhhhhhhh...you're exposing my secret and those environmental cops might be watchin!
juggler Posted October 16, 2007 Posted October 16, 2007 Last time I did this, I used a Tupperware container that almost overflowed by the time all the oil drained. I'm looking for something that will fit under my Sears bike lift, maybe 12"L x 10"W x 6"D. Any suggestion are greatly appreciated. Thanks. I bought a normal circular car oil drain pan. It fits under the bike with the bike on my Carbon One lift adapter. Get the lift adapter with legs. You won't regret it.
BMW Posted October 16, 2007 Posted October 16, 2007 I put the bike up on the center stand and use a large paint roller pan and it works just fine.
Neil86 Posted October 16, 2007 Posted October 16, 2007 I use a shallow Wedco oil drain pan /container...has shallow funnel that stores on the side of the container...holds about 7 US quarts....can store the oil till disposal. Looks like this one [ame=http://www.amazon.com/Wedco-Quart-Oil-Drain-Pan/dp/B000I2UVPE]Amazon.com: Wedco 7 Quart Oil Drain Pan: Automotive[/ame]
Blackjack Posted October 16, 2007 Posted October 16, 2007 I have used the same device as Neil86 for over 10 years! The only thing you have to clean when you're done is the funnel section, which is quick and easy. After that it easily stores until you need it again or it gets full. When it does get full I take it to a nearby Pep Boys and empty it in their oil barrel, at no charge! Terry
KiteSquid Posted October 17, 2007 Posted October 17, 2007 I do wish that Rubbermaid would make their drain pan again. It holds about 15 quarts and the entire lid screws off and on, so you don't have to wipe down a funnel section before transporting to the oil recycling in your area. The only down side was I had to be careful when screwing on the lid to keep from cross-threading it.
awsmsrv Posted October 17, 2007 Author Posted October 17, 2007 Thanks everyone. I do have Larry's lift adapter, but not the legged one. I'm thinkin' the best idea is just not lift the bike. Solves the fit issue. Thanks again.
Pyro Posted October 18, 2007 Posted October 18, 2007 I put the bike up on the center stand and use a large paint roller pan and it works just fine. Another genius among us. This is what I do as well. (Paint Roller pan,) But my RSV has no center sand, so I just sit on it & hold it upright to get the lst few drops of oil out. I place the old oil back into the quart containers that the new oil came in. I save some of it for odd's & ends where dirty oil works well. The surplus I discard at the landfill in the designated area. Pyro
