barend Posted May 1, 2010 #1 Posted May 1, 2010 I'm replacing the steering head bearing on my '83. The manual says 5.1 ft/lbs. Where have you adjusted yours to with the hack attached? I've been told that you can tighten it down more to prevent wobble with the hack. Thanks
Squeeze Posted May 1, 2010 #2 Posted May 1, 2010 Well, i don't have any Knowledge about running a Hack, but i wouldn't suggest much more clamping Force on the Bearing. A bit more may be ok, but much more will ruin the new Bearings premature and create Problems when trying to run a straight Line. I'd stay within the upper End of the Specs. Lift the front Wheel off the Ground and place the Steering into middle Positon. The Front End should fall to either Side with a little Push, but not rebounce from the Stop. If the Fork won't reach the Stop on both Sides on it's too tight, if it rebounces once or twice it's too loose.
MiCarl Posted May 1, 2010 #3 Posted May 1, 2010 Well, i don't have any Knowledge about running a Hack, but i wouldn't suggest much more clamping Force on the Bearing. A bit more may be ok, but much more will ruin the new Bearings premature and create Problems when trying to run a straight Line. I'd stay within the upper End of the Specs. Lift the front Wheel off the Ground and place the Steering into middle Positon. The Front End should fall to either Side with a little Push, but not rebounce from the Stop. If the Fork won't reach the Stop on both Sides on it's too tight, if it rebounces once or twice it's too loose. Agreed. Go over and you risk bearing damage.
dingy Posted May 1, 2010 #4 Posted May 1, 2010 The 86-93 manual shows different procedure for setting steering head. At the bottom of my first post in the thread link below is a pdf file showing the MKII procedure, which I like better than the MKI. http://www.venturerider.org/forum/showthread.php?t=45268 The MKII shows tightening the nut up the releasing pressure and re torqueing. Gary
barend Posted May 2, 2010 Author #5 Posted May 2, 2010 No more clicking, no more clacking. no more wobble:cool10: Thanks to all who assisted in resolving this problem. Might be torqued a little harder then suggested but that's OK. I am happy!:sun:
