Whistler Posted April 24, 2010 #1 Posted April 24, 2010 I,ve been reading in the book that the engine oil also is used for the culch but is it also for the trans... And while i,m at it is the bearings on the shaft sealed or do I grease them....So much to learn Ron (Whistler:cool10:)
SilvrT Posted April 24, 2010 #2 Posted April 24, 2010 Whistler said: I,ve been reading in the book that the engine oil also is used for the culch but is it also for the trans... And while i,m at it is the bearings on the shaft sealed or do I grease them....So much to learn Ron (Whistler:cool10:) yep, lots to learn... welcome the Engine, Clutch, Trans are all lubed by the same oil in an RSV. What bearings on what shaft are you talking about?
Whistler Posted April 24, 2010 Author #3 Posted April 24, 2010 Thanks for the info as far as the bearing I was talking about ... The bike being shaft driven I just thought that there was something like u joints bearings or something as i said I got things to learn ..Every bike I,ve had in the past there is always something different Whistler:cool10:
