Snaggletooth Posted April 19, 2010 Share #1 Posted April 19, 2010 Ok.....I still have one thing that irks me about the looks of my bike. The tops of the dash panels where they mount to the stays. Both of mine are damaged at that spot only. Otherwise they are in fine shape but the right side has both holes broken through and pieces missing. The left side only has one damaged. Since I got the bike I have used chrome washers with bib washers under them to cover the damaged area but would like to do something to cover the whole top of panel with an angled lip to drop down to cover the area above the speakers. As there is somewhat of a curvature there a simple bend with flat material won't work cleanly. I like to use thin gauge SS sheet of possible to somewhat match the chrome trim pieces on the sides of the fairing. I could live with a painted material if it come to that. Spacers would be attached to the back to fit into the recess in the plastic to avoid bending the trim into the hole. Any suggestion? I know I can't be the only one with this damage. Mike Link to comment Share on other sites More sharing options...
bongobobny Posted April 19, 2010 Share #2 Posted April 19, 2010 I ended up installing flat washers and used 2 part plastic epoxy to "weld" them in place. A little sanding and a new Sharpie made them look presentable... Link to comment Share on other sites More sharing options...
Wizard765 Posted April 19, 2010 Share #3 Posted April 19, 2010 Ok.....I still have one thing that irks me about the looks of my bike. The tops of the dash panels where they mount to the stays. Both of mine are damaged at that spot only. Otherwise they are in fine shape but the right side has both holes broken through and pieces missing. The left side only has one damaged. Since I got the bike I have used chrome washers with bib washers under them to cover the damaged area but would like to do something to cover the whole top of panel with an angled lip to drop down to cover the area above the speakers. As there is somewhat of a curvature there a simple bend with flat material won't work cleanly. I like to use thin gauge SS sheet of possible to somewhat match the chrome trim pieces on the sides of the fairing. I could live with a painted material if it come to that. Spacers would be attached to the back to fit into the recess in the plastic to avoid bending the trim into the hole. Any suggestion? I know I can't be the only one with this damage. Mike Why not repair the holes with Plastex and be done with it. Then they get mounted properly and look fine. Wayne Link to comment Share on other sites More sharing options...
GigaWhiskey Posted April 19, 2010 Share #4 Posted April 19, 2010 I bought new ones of those. I didn't mess with mine. I have no ideas for you either. Sorry. Link to comment Share on other sites More sharing options...
