bkuhr Posted April 18, 2010 #1 Posted April 18, 2010 What is proper assembly of rear wheel on 83 xvz12? From right 1. axle bolt 2. washer 3. brake caliper bracket 4. ??missing spacer?? 5. RH oilseal and bearing 6. etc... I seem to have too much gap on right side, and brake caliper bracket is clear to move too far?? toward wheel, bumping brake rotor bolt heads
dingy Posted April 18, 2010 #2 Posted April 18, 2010 (edited) See this link. http://www.venturerider.org/forum/showthread.php?t=515 Sent you an email with some other pictures. Gary Edited April 18, 2010 by dingy
bkuhr Posted April 18, 2010 Author #3 Posted April 18, 2010 Thanks for link, no email came thru Found missing spacer, fell out of wheel (unobservered by me-radio too loud) and rolled into corner. Reassembled, looks correct now. Still no answer if I have problem with lower shock bushing http://www.venturerider.org/forum/showthread.php?t=47662 Brian
dingy Posted April 18, 2010 #4 Posted April 18, 2010 Sent email to wrong person, OPPS! Look at link below, it has an exploded view of rear suspension. http://www.venturerider.org/forum/showthread.php?t=1057&highlight=swing+grease+zerks Gary
