EFudd Posted April 14, 2010 #1 Posted April 14, 2010 Taking a right hand corner with plenty of lean my spring loaded right floor board drags. Taking a left corner with plenty of lean the boot loop on the kick stand (it is fully up) drags and recently caused the back wheel to hop right a few inches. That was a little unsettling. Didn't pay much attention for location of wear and tear until that wheel hop thing. After examining the kickstand loop. it appears that the bottom side is now about half worn through. Am I way too aggressive in the corners? lol Is my experience normal or is there something wrong with the kick stand or something else? Jack
slick97spirit Posted April 14, 2010 #2 Posted April 14, 2010 Dang dude, slow down and enjoy the scenery!!!
hig4s Posted April 14, 2010 #3 Posted April 14, 2010 How much air pressure do you have in your forks and shocks? Also if you are going to ride a shaft drive cruiser aggressively you should shift your weight to the inside of the corner by looking around the inside of the windshield, and slow before the corner so you can be slightly on the gas though the whole corner. Being on the gas, even a little, on a shaft drive bike raises the rear suspension some.
EFudd Posted April 14, 2010 Author #4 Posted April 14, 2010 Front shocks 6#s, rear about 40#s. Guess I'll have to make some changes to my riding style ( if there was any before - lol). Jack
eazyduzzit Posted April 14, 2010 #5 Posted April 14, 2010 I've had my '05 RSTD over a year and haven't dragged the boards but twice. Both times it was the board that dragged and not the stand I don't understand why yours is dragging. Has it been lowered?
EFudd Posted April 18, 2010 Author #6 Posted April 18, 2010 I figured it out. Last year rode off the pavement and caught some shoulder gravel on the side stand side. The side stand was jammed and had to put a heavy boot to get it to come down. Must have bent the loop. Now it's closer to factory position. Thanks all for you help. Jack
