MrRadi8 Posted October 13, 2007 #1 Posted October 13, 2007 From the letter I received from Avon, I just came back from putting 42 psi front and 48 psi rear. DO IT!!! That's what I was looking for when I bought the Avon's in the first place. High speed much improved and sticky in the twisties. Try it, you'll like it.
eagleeye Posted October 13, 2007 #2 Posted October 13, 2007 I'd be interested in reading the letter. Steve
MrRadi8 Posted October 13, 2007 Author #3 Posted October 13, 2007 I'd be interested in reading the letter. Steve http://forums.delphiforums.com/vrider/messages?msg=5941.7
midnightventure Posted October 15, 2007 #4 Posted October 15, 2007 I asked Avon what pressure to run when I replaced mine recently and this is what they sent me. General Tire Pressure Guidelines – Avon Tyres Based on a 170 lbs. rider with no luggage For 2 up or bigger loads increase accordingly Venom Tires with reinforced construction (150/90B15, etc.) Solo 2 up light 2 up loaded Front 38-40 40-41 42-43 Rear 44 46 48-50 Other Models – Venom (not reinforced or radial, 150/80-16), Roadrunner, Roadrider, etc. Solo 2 up light 2 up heavy Front 34-38 40-42 42 Rear 38-40 40-42 42 General Size/Pressure Chart Front Solo 2 up light 2 up heavy 80/90-3.25 32-34 32-34 34-36 100/80-3.50 32-34 34-35 35-36 110/70-120/90 34-36 36-38 36-38 130/60-150/80 34-36 36-38 38-40 Rear Solo 2 up light 2 up heavy 4.00-100/90 34-36 36-38 38-40 4.25-110/90 34-36 36-38 38-40 120/80-130/90 36-38 38-40 40-42 140/70-190/50 36-38 38-40 40-42 140/90-200/50 38-40 40-42 40-42 Note: This is a wide range recommendation for average conditions only. High speed riding and/or high road temperatures may require a moderate increase in pressure, not to exceed the indicated maximum cold pressure on the sidewall. Contact Avon directly for exact pressure recommendations for your riding conditions. These are general guidelines only. Avon Tyres Customer Service 6911-A 216th St. S.W. Lynnwood, WA 98036 Toll Free 1-800-624-7470 Fax 1-425-771-4246 Sorry it didn't line up very good.
