Snaggletooth Posted April 11, 2010 Posted April 11, 2010 I just got the job of doing the up keep on a pair of 2009 CT50s. 800cc. Trying to track down which oil filters will fit. If I got this right they have the 20x1mm thread on the filter, the same as the VL800 Intruder. Anybody got any info on oil filter numbers that will match up? Thanks Mike
Snaggletooth Posted April 11, 2010 Author Posted April 11, 2010 That should take a while to down load but looks like it will be helpful. Thanks Mike
flb_78 Posted April 11, 2010 Posted April 11, 2010 http://www.calsci.com/motorcycleinfo/FilterXRef.html [2] These Oil Filters have 20 x 1mm threads, 11 psi by-pass valve, anti-drain back valve. None are recommended. This is a proprietary Suzuki thread, and no high performance filters are made for 20mmx1mm threads. Available filters include: AMSOil SMF 109 Bike Master 314-0025 Champion PH7016 Cycle Power 314-1919 Emgo 10-55662 Emgo 10-55660 Fram PH6018 Hi-Flo HF138 J.C.Whitney ZX063166P K&N 138 NAPA 1359 / WIX 51359 NAPA PS7937 Parts Unlimited Per-Form J-509 ProPart 01-0029 Purolator ML16818 STP SMO-18 Suzuki 16510-03G00-X07 VESRAH vsf-3009 WIX 57937
Snaggletooth Posted April 11, 2010 Author Posted April 11, 2010 Yep! That should cover all the bases! I love multiple choice. Thanks Mike
