First_N_Last Posted April 6, 2010 Posted April 6, 2010 Ok... I've been doing a lot of searches for a front tire to match my rear Kumho on my 2008 VRS. The narrowed down choices for me are: - Bridgestone Battlax BT-020 150/80R-16 71V - Michelin Commander 130/90H-16 - Michelin Commander 150/80H-16 - Avon AM41 Venom 150/80H-16 I want a radial - straight tread in the middle - high mileage - reliable. There is at best 2500 miles left on mine (2 months riding). Any suggestions, comments or experience to share from the Dark Siders? johnb
Kregerdoodle Posted April 6, 2010 Posted April 6, 2010 alot of guys are going with the Avon Viper , it is a Radial and has good tread pattern..
First_N_Last Posted April 6, 2010 Author Posted April 6, 2010 This is my favorite of the bunch so far... Bridgestone - G853 Exedra OE Radial Front Tire Size - 150/80VR-16 G The tread seems to be the best to prevent wobble. After I put my CT on I had wobble on curves above 70. It appears that as the front tire has continued to wear, the wobble has moved up in speed to wear it wobbles on curve up grades above 80 or 90. I want as much straight deep tread in a radial to match the Kuhmo, as I can get.
Wanderer Posted April 7, 2010 Posted April 7, 2010 This is my favorite of the bunch so far... Bridgestone - G853 Exedra OE Radial Front Tire Size - 150/80VR-16 G The tread seems to be the best to prevent wobble. After I put my CT on I had wobble on curves above 70. It appears that as the front tire has continued to wear, the wobble has moved up in speed to wear it wobbles on curve up grades above 80 or 90. I want as much straight deep tread in a radial to match the Kuhmo, as I can get. I thought you were asking? I too have to soon replace the front to go with my Kumho. Have you been using the Exedra, or are you planning to? If just planning what have you had on the front. I still ride the OEM Dunlop. I understood many were going with a Pirelli rear reversed on the front.
First_N_Last Posted April 7, 2010 Author Posted April 7, 2010 I thought you were asking? I too have to soon replace the front to go with my Kumho. Have you been using the Exedra, or are you planning to? If just planning what have you had on the front. I still ride the OEM Dunlop. I understood many were going with a Pirelli rear reversed on the front. I currently have a worn OEM Dunlop on the front & am looking for a better replacement. A Pirelli rear reversed on the front? Have many done that & been happy?
Wanderer Posted April 7, 2010 Posted April 7, 2010 (edited) I currently have a worn OEM Dunlop on the front & am looking for a better replacement. A Pirelli rear reversed on the front? Have many done that & been happy? I could be wrong, but I think I got most of my info from here. Still am researching myself. Just like deciding to go to the darkside I'll try to make a decision that seems right to me, given all the input I can get. Edited April 7, 2010 by Wanderer add text
Wanderer Posted April 7, 2010 Posted April 7, 2010 I think I may try the Pirelli Route66 rear mounted reverse. It's not a radial, but I've used them before on a cruiser with good results and better than average wear. The rear on the front should provide for excellent mileage and I love the looks of the tread.
footsie Posted April 7, 2010 Posted April 7, 2010 Guys I had no trouble with the Avon Cobra Radial on fount with the kumho on back, have on 10,000 miles on both, with very little wear. Gregg
First_N_Last Posted April 7, 2010 Author Posted April 7, 2010 Guys I had no trouble with the Avon Cobra Radial on fount with the kumho on back, have on 10,000 miles on both, with very little wear. Gregg Thanks for the experience info on the Avon Cobra...
First_N_Last Posted April 7, 2010 Author Posted April 7, 2010 I could be wrong, but I think I got most of my info from here. Still am researching myself. Just like deciding to go to the darkside I'll try to make a decision that seems right to me, given all the input I can get. Thanks... that web site has a lot of info. It was interesting to know that some Valkyrie bikes shipped with Bias on the front & Radial on the rear. It seems that the long term users also recommend Rear Bias tires on the front & to mount them with mounting direction normal (not reversed). A rear tire on the front is definitely NOT going to make it easier to handle my bike at less than 10 mph. However, it seems that the more you ride, the stronger your upper body gets to BULL it around. I have to admit that I now have more to consider. johnb
1joeranger Posted April 7, 2010 Posted April 7, 2010 I have about 8k to go before I am done with my front Avon Venom. I had planned on replacing it with a Cobra Venom! I look forward to the continued updates to this thread! Intrigued about reversing a rear tire but only if the benefits outweigh the side effects!!!!
pegscraper Posted April 7, 2010 Posted April 7, 2010 I'm running the Avon Venom rear tire in reverse on the front. No negative side effects, unless someone thinks longer tire life is bad. I ran this tire all last summer and I'm a long ways from having to replace it. I won't have to buy another tire for the front this year.
BigBoyinMS Posted April 7, 2010 Posted April 7, 2010 The recommended tire on the Delphi Darksiders forum is the Pirelli MT66. And whenever I need a new front I'll probably go with that... but for the time being I have the correct front ME880 on the front and it's been great. The biggest thing is correct tire pressure, no matter what tire you use. If my experiences are any indicator then most gauges are not correct. That could be part of the wobble issue some have reported.
Wanderer Posted April 7, 2010 Posted April 7, 2010 The recommended tire on the Delphi Darksiders forum is the Pirelli MT66. And whenever I need a new front I'll probably go with that... but for the time being I have the correct front ME880 on the front and it's been great. The biggest thing is correct tire pressure, no matter what tire you use. If my experiences are any indicator then most gauges are not correct. That could be part of the wobble issue some have reported. Yeah, that's the site, but I've lost the bookmark. I did a google, but didn't come up with it. Can you post it BigBoy. Thanks
First_N_Last Posted April 7, 2010 Author Posted April 7, 2010 Yeah, that's the site, but I've lost the bookmark. I did a google, but didn't come up with it. Can you post it BigBoy. Thanks Wanderer gave this link http://mcdarksiders.forumotion.com/forum.htm
BigBoyinMS Posted April 7, 2010 Posted April 7, 2010 Here ya go... Delphi's "Riding the Dark Side" forum
First_N_Last Posted April 8, 2010 Author Posted April 8, 2010 Well, I have placed my order for a tire. My front tire tread depth is down to about 1/32. Normally I would have bought the Pirelli MT66, but I found a good price on a venom. I have bought... 150/80HB-16 (77H) Avon Venom AM42 Rear Motorcycle Tire Black Wall from www.jakewilson.com for $135.99 with free shipping also found a $25 mail in rebate from Avon Final Cost will be $110.99 The tire should be here in 3 work days or less & mounted by next weekend. Tire will be mounted with peak of tread lines pointing up as viewed from the front (probably reversed). More status to come... johnb
First_N_Last Posted April 9, 2010 Author Posted April 9, 2010 Received email last night (4/8) indicating that my tire has shipped via UPS.
gunboat Posted April 9, 2010 Posted April 9, 2010 i also have the avon croba on the front. i was using a me 880-130 on the front, used it with the bfg 155. i racked up over 31,000 miles on the bfg before switching to a kuhmo. the croba and kuhmo work well together in my personal experiance, i have about 8,000 miles on this combo. reguards don c.
Wanderer Posted April 9, 2010 Posted April 9, 2010 Ordered the Pirelli Route MT66 rear for the front today. Mostly because I have a history with the tire and I like the looks and they wear real well.
footsie Posted April 11, 2010 Posted April 11, 2010 Thanks... that web site has a lot of info. It was interesting to know that some Valkyrie bikes shipped with Bias on the front & Radial on the rear. It seems that the long term users also recommend Rear Bias tires on the front & to mount them with mounting direction normal (not reversed). A rear tire on the front is definitely NOT going to make it easier to handle my bike at less than 10 mph. However, it seems that the more you ride, the stronger your upper body gets to BULL it around. I have to admit that I now have more to consider. johnb I don't know about all, but the book with MY Valkyrie had in big red letters to never put a bias ply tire on a Valkyrie, that it would cause instability. The Valkyrie's were specifically designed for radials only. Gregg
footsie Posted April 11, 2010 Posted April 11, 2010 Take a look, this is 9685 miles on a avon Cobra Radial. 11,000 on the kumho, not much wear at all. Gregg
First_N_Last Posted April 13, 2010 Author Posted April 13, 2010 My AM42 Venom tire arrived today. I pulled off the front wheel & am getting the new tire mounted tomorrow. Hopefully I'll get the bike back together tomorrow night & take a quick test ride before dark. johnb
Wanderer Posted April 13, 2010 Posted April 13, 2010 My AM42 Venom tire arrived today. I pulled off the front wheel & am getting the new tire mounted tomorrow. Hopefully I'll get the bike back together tomorrow night & take a quick test ride before dark. johnb Super! I'll be putting my Pirelli on the front Saturday, maybe we can make some in time comparison's? Might be interesting.
First_N_Last Posted April 14, 2010 Author Posted April 14, 2010 Super! I'll be putting my Pirelli on the front Saturday, maybe we can make some in time comparison's? Might be interesting. Yes... actual comparison will be great for us & others. I ride at least 10,000 motorcycle miles each year. The tire is on, I will report the mileage, set the tire pressure & take a quick highspeed test ride for wobble. Then I will report it here. johnb
