Tony1M Posted April 2, 2010 Posted April 2, 2010 I started the bike this morning for the first time this season. For the first time ever, I had the battery plugged into a battery-minder through the winter. The battery remained in the bike throughout the winter. (I have a permanent charger-connector on the battery and am able to connect the charger to it via a cable whose end is available externally.) When I turned the key I got the usual run-through of alarms on the dispaly, but the low-electrolyte alarm stayed on. I removed the cover and the electrolyte level in the sensor's cell, as well as the rest, seemed OK to me, so I removed the sensor, dipped it in a glass of water and the alarm stayed on. I think that I might have a bad sensor, but I'm not sure about that. Anyway, after determining that the battery level was OK, I put things back together, started the bike and went out for a ride. The bike started and ran beautifully. I want to have a working sensor and NOT do the resistor "mod" to eliminate the alarm, so: 1. Do these battery sensors occasionally fail? 2. Is dipping the sensor in a glass of water an adequate way to test it, or is the electrolyte part of the circuit? If so, should I just add demin water regardless of the present level in that cell? Any suggestions would be welcome. Thanks.
scotty Posted April 2, 2010 Posted April 2, 2010 Your probe is likely corroded and not completing the circuit. You could try cleaning it with steel wool. I think I still have one here if you want it. Scotty
Tony1M Posted April 2, 2010 Author Posted April 2, 2010 Scotty, thanks! First, I'll try the steel wool method and report back.
Tony1M Posted April 3, 2010 Author Posted April 3, 2010 Well, I was wrong. I added water to the upper level mark and the alarm went bye bye. The sensor was just doing it's job and my eyes were not. I filled the rest of the cells to the same level. Thanks again for the offer, scotty. I appreciate it.
barend Posted April 3, 2010 Posted April 3, 2010 FWIW The sensor only monitors the level in that particular cell (my opinion) which makes it essentially useless as an overall battery condition indicator
Pappa Bear Posted April 4, 2010 Posted April 4, 2010 I just replaced my battery and did the resistor bypass, worked fine!
jasonm. Posted April 4, 2010 Posted April 4, 2010 the sensor works like this...It passes and electrical signal to the monitor system. In this case for the monitor to shut off the "alarm" it needs 5 volts. The electrolite in the middle cells give a total of approx 6-7 volts+ when testing to ground. But if the electrolite does not touch the sensor the result is NO voltage to the system. Thus the alarm. So sticking it in a glass of water does not send the needed voltage.
