I am not sure if it is a bug, I missed something or I imagined it.
I would swear there was a multi quote button in the threads.
I switched to the venturerider theme and did not see it when on that theme either.
Jeez.......................I learn something new every day here.
I've always wondered how people do that.
Now, I hit the button, but nothing happened.
How does a person use it?:think:
You just hit the multi quote button for every post that you want to respond to. Then you git the reply button. That copies the text of the selected posts to your reply and you just insert your responses after the /quote tag of each one.
Good...you found it before I even had to look. :)
Sometime we can suprise you....
Alrighty then....thank you sir for the directions.
I just love the "helpful hints" section of this forum!!!
Hey that works too.
I click (not GIT) the multi quote button then on the last persons quote I wanted, I click on there quote button, which works as well.
Brad
