GigaWhiskey Posted April 1, 2010 #1 Posted April 1, 2010 I am not sure if it is a bug, I missed something or I imagined it. I would swear there was a multi quote button in the threads. I switched to the venturerider theme and did not see it when on that theme either.
GigaWhiskey Posted April 1, 2010 Author #2 Posted April 1, 2010 My bad. Now I see it. Big blind dummy here, lol.
BradT Posted April 1, 2010 #4 Posted April 1, 2010 The multi post button has no label so it is easy to miss. Brad
BradT Posted April 1, 2010 #6 Posted April 1, 2010 What multi-quote button.... It's the one without the label Brad
Iowawegian Posted April 1, 2010 #7 Posted April 1, 2010 Jeez.......................I learn something new every day here. I've always wondered how people do that. Now, I hit the button, but nothing happened. How does a person use it?
Freebird Posted April 1, 2010 #8 Posted April 1, 2010 You just hit the multi quote button for every post that you want to respond to. Then you git the reply button. That copies the text of the selected posts to your reply and you just insert your responses after the /quote tag of each one.
Iowawegian Posted April 1, 2010 #9 Posted April 1, 2010 Good...you found it before I even had to look. Sometime we can suprise you.... You just hit the multi quote button for every post that you want to respond to. Then you git the reply button. That copies the text of the selected posts to your reply and you just insert your responses after the /quote tag of each one. Alrighty then....thank you sir for the directions. I just love the "helpful hints" section of this forum!!!
BradT Posted April 2, 2010 #10 Posted April 2, 2010 Then you git the reply button. Hey that works too. I click (not GIT) the multi quote button then on the last persons quote I wanted, I click on there quote button, which works as well. Brad
