I've read a lot on just about everything here. Have received a ton of info and appreciated it all. Made a lot of upgrade decisions and changes from all the info here. All has been great. Put on some Baron Risers over the past couple of weeks along with some other upgrades which I'll write about later.
My question is, I have no problem with my cable lengths and the risers but, the risers hit the black plastic switch cover prior to the stops.
Does anyone else have this issue and if so, what if anything have you done to correct it.
Thanks
Yup, that's one of the issues with using the risers. Won't hurt anything unless you have installed the chrome ring around the switch to replace the rubber one. The chrome one won't give and will crack or the chrome will chip off.
I corrected it by installing Flanders G2 bars.
