Chezley Posted March 27, 2010 #1 Posted March 27, 2010 I know that new bearings on big machinery can get a bit hot, sometimes to the point of boiling the grease, until they wear in. Just wondered about smaller ones, like say car or m/c wheel bearings? My guess is they do to some extent & I bet some of you guys will know for sure. Tony.
Guest seuadr Posted March 27, 2010 #3 Posted March 27, 2010 yes, wheel bearings get hot enough to melt the heavy duty grease in them, thats part of the reason that most wheel bearings are sealed, to keep that hot, liquid grease inside. if you had a bearing in your wheel that was not sealed i would highly recommend greasing it on a regular basis. you'll know if it starts to cook out the grease, as you will hear a high pitched squeek that is speed dependant.
Chezley Posted March 27, 2010 Author #4 Posted March 27, 2010 GeorgeS I mean any ball race bearings & needle bearings. Seuadr, thank you kindly, that is the answer I was sort of expecting. Tony.
