installed ......and picked up bike today.....definitely gone.....
WOOOOOOOHHOOOOOOOOOO!!! :thumbsup2: :thumbsup2:
You might want to consider adding a bit of MotorKote to your oil just for that added "wear-in" of the gearset.
Glad to hear it! I hope I can say the same. Mine is going in April 12th. I already checked the clutch basket and it is definitely the "I" version.
I put a small dose of motor kote in last fall. MISTAKE !! The wine is louder now than ever. I don't know whether it was the amziol or the motor kote but they are BOTH going before I start riding this year, back to Mobile 1 and no additives
This is so strange how all this is so much different in each bike, I am the opposite of Adventure 1943, If I use Mobile mine gets louder and the MotorKote and the Amzoil I use makes it better, I just can not figure why this happing. I also am going to try next week , installing a 3rd (I) Basket myself. Just to see if there as been any changes at all in the gear cut after 5 years. If it doesn't work it The basket will be for sale. my own experiment. I will also be measuring my old (I) against the new one.
So far I have used (D) (E) (F) (G) (I) (I) in my bike.
Jeff
Lots of folks swear by Amsoil. I tried it last year (before the I basket when I had the whine) ... made the whole engine sound noisier...not sure if the whine was worse or not. I'm now using Rotella T 15w40. The engine is the quietest that it's ever been and I'm quite happy with it now... to me it sound like it should sound.
been using the rotella t syn(blue jug) in my Triumph for years, no probs with wet clutch . will be doing an oil change in the rsv this weekend with the rotella t.
I switched from regular rotella to the sythetic and everything seems very happy. For me the whine has decreased, maybe to the thinner or lighter weight oil. Mine screams with a heavey 20w-50.
You do not know until you pull it out. I do not have any idea if they install the (I) basket at the factory or not. the markings are on the back of the basket.:cool:
Jeff
Thanks, I see the "G" as indicated. I was hoping to be able to tell which basket I have without teardown but I guess that isn't possible.
