remmertb Posted March 24, 2010 Posted March 24, 2010 I made one of these and it works perfectly. I used old motor oil for the liquid. Sync #1 to #2, then plug those and sync #3 to #4. Then hook up tool to #2 and #4 to sync left side to right side (make sure to plug ports on #1 and #3).
SilvrT Posted March 24, 2010 Posted March 24, 2010 FYI ... the website listed in that document (http://www.powerchutes.com/prairieskyhook.htm) is not valid (HTTP 404 error)
massey130 Posted March 24, 2010 Posted March 24, 2010 looks like that would do the trick. I already popped for a 4 dial gauge setup. it was 45 bux and shipping was included. If all goes as planned (right!) i will learn to use it coming weekend.
tsigwing Posted March 24, 2010 Posted March 24, 2010 or you could build two of them and not have to switch them to do the sync
SilvrT Posted March 24, 2010 Posted March 24, 2010 or you could build two of them and not have to switch them to do the sync that would double the cost .... too expensive!!!
mrich12000 Posted March 26, 2010 Posted March 26, 2010 :Im not listening towow so much info, you need to buy four Gage's. Tractor supply, Ford distributor restrictions for pulsations,(Available also at Napa ,Car quest) @eight feet of 1/8 windshield washer hose, and some of the knowledge gathered here. Also check the post for other fine suggestions. Cheers Michael.. Cost @ 10.00 can
djh3 Posted August 27, 2012 Posted August 27, 2012 I know old post. But I ran across a couple of vacuum gauges I had previously used to sync my FJ motor I had in a Legends Car. Best to connect all gauges to the same port to verify if they actually read correctly and the same. On the thought of building a liquid type syncronizer I have seen this article before for the $1.55 tool. But when I saw pics of this thing actually built it is massive. Like 4-5' tall and a couple feet wide if you build it for 4 cyl. I had a thought what if you used say a 12" or so wide piece of PVC say 1" diam cap the ends and then install screw in ports. Fill the PVC with your fluid say auto trans fluid. Could you not use shorter hoses then like maybe 2ft long. Sure would make it easier to store.
tz89 Posted August 27, 2012 Posted August 27, 2012 Just for fun I'm building a digital sync tool out of old GM MAP sensors. I'll post with pics when it's done. I'm trying to get it to display wirelessly on a smart phone, but if not I'll just use an lcd screen. Stay tuned! Tom
