MikesBike Posted March 22, 2010 Share #1 Posted March 22, 2010 I have an '89 VR and I've seen many posts telling me to move the TCI from it's mounted location to the top of the air filter box. Well, I've spent the last three days working on this and other mods to come to the conclusion that the TCI won't let the faux cover fit. It's being held off by at least a half inch. I'm wondering if I should cut the TCI mounting tabs off to provide a little more clearance. Any help would be appreciated. Link to comment Share on other sites More sharing options...
Squidley Posted March 22, 2010 Share #2 Posted March 22, 2010 Mike, Yes cut the back tab off so you can push the TCI more forward on the front of the airbox. It is a tight fit but it will work, I have done half a dozen like that. Give me a call if you get to a spot where you need a voice Link to comment Share on other sites More sharing options...
MikesBike Posted March 22, 2010 Author Share #3 Posted March 22, 2010 Thanks Brad, I couldn't see any other way to make it fit but I had never seen it mentioned in any of the posts to cut off the tab. I guess it's possible that I just overlooked it... Thanks for your help! Link to comment Share on other sites More sharing options...
painterman67 Posted March 22, 2010 Share #4 Posted March 22, 2010 yeah I couoldnt get mine out by removing the screws so the tabs are still in there. I just used a mini saw , a mirror, and a shop towel set on top of the carbs to keep trash out and cut away.The cdi sets on top of the airbox well now. David Link to comment Share on other sites More sharing options...
MikesBike Posted March 23, 2010 Author Share #5 Posted March 23, 2010 Well, I cut the tabs off this morning and tried it again. The fit was closer but still not enough to put the cover screw in. Is there an alternate mounting method without sticking it back under the battery? Any pictures or ideas appreciated. Link to comment Share on other sites More sharing options...
Squidley Posted March 23, 2010 Share #6 Posted March 23, 2010 Mike, Try this thread K bran posted pics of the one on your old '86 that I sold him http://www.venturerider.org/forum/showthread.php?t=26864&highlight=TCI+airbox Link to comment Share on other sites More sharing options...
MikesBike Posted March 23, 2010 Author Share #7 Posted March 23, 2010 Thanks for the pictures Brad, I sure missed that bike after I sold it I'm glad it found a good home. I'll have another try after I get back home later this week. Link to comment Share on other sites More sharing options...
MikesBike Posted March 28, 2010 Author Share #8 Posted March 28, 2010 After a week of thinking about my cover problem (well, I didn't think too hard) I came to the conclusion that there must be something about the cover causing the interference. The nagging thought that this lid weighed more than the one on the '86 I used to have and the '83 I played with for a while kept surfacing. First thing I did after getting home was look at the bottom of the lid and sure enough, someone had added a quarter inch thick layer of tar coated noise insulation. It had bubbled from years of heating and had separated from the cover in several places. This stuff was as stiff as a board and had caused the TCI to not fit. After removal, the TCI fits snug as a bug on top of the air box. Thanks David and Brad for all your help! Link to comment Share on other sites More sharing options...
Squidley Posted March 29, 2010 Share #9 Posted March 29, 2010 Mike, Glad to hear you got it figured out I recommend all the 1st genners doing this as it makes it so much easier to swap out a TCI unit when it's right in front of your face Link to comment Share on other sites More sharing options...
Grandpagak Posted March 29, 2010 Share #10 Posted March 29, 2010 what is the purpose for moving the cdi box?? just wondering if i should do so also?? Link to comment Share on other sites More sharing options...
Squidley Posted March 29, 2010 Share #11 Posted March 29, 2010 what is the purpose for moving the cdi box?? just wondering if i should do so also?? Gary, It's basically just an ease of maintenance thing. They are in such a lousy spot that if you have issues with them it's way easier to lift the faux cover off and have it right there at your finger tips. Besides being under the battery and a bad spot to get to, any battery malfunction resulting in acid can make it onto and possibly into the TCI...and that really sucks! Link to comment Share on other sites More sharing options...
Yammer Dan Posted March 29, 2010 Share #12 Posted March 29, 2010 Helps to keep it dry. Where Yamaha puts it sooner or later it seems to get wet. Link to comment Share on other sites More sharing options...
Ottawa Posted March 30, 2010 Share #13 Posted March 30, 2010 I did it to the 83 and will do it to the 85 now that its apart for painting. Its hard to get at but if it develops a gap, and it will, you will be soooo happy you moved it. Especially if you go through some rain. When the 83 got wet I tried to just run it around the bock. Man did it miss, but, when all cylinders kicked in I almost lost both arms not to mention control. Link to comment Share on other sites More sharing options...
