Venturous Randy Posted October 10, 2007 #1 Posted October 10, 2007 Take the trunk off and on the rack that it sits on, put some 1/2 inch inside diameter by an inch or so long pieces of hose on where the rubber pads are on the underside of the trunk. Just slit the pieces of hose lengthwise and wrap them around the rack. When you put the trunk back on you may need to wiggle it side to side some and pull backward. Once you get it on and locked, it will be nice and snug!! RandyA
Condor Posted October 10, 2007 #3 Posted October 10, 2007 My original '83 had foam insulation strips stuck to the top of the rack rails. Worked pretty well too.....
KingSizer Posted October 10, 2007 #5 Posted October 10, 2007 I noticed when I took the trunk and bags off my 84 the po had wrapped tape around the rails to increase the diameter. One spot had duct tape and the other had plain old black electrical tape. Seems to work fine, not loose at all.
