Pappa Bear Posted March 18, 2010 #1 Posted March 18, 2010 I'm replacing my stock CB/Radio antenna on the VR with a Firestik . I looked at the new antenna and of course it has a male end. So I want to replace with all new from the antenna to the CB. I see that I will need different parts to hook this up. One end of the old coax has the plug in type of connector (like on a car radio antenna wire)at the CB and the other end has the old mounting unit built right on it. Where can I get coax with the plug on one end and the screw on connector at the other end by the new mounting stud? OR ----- can I cut the old original mounting end off and put on a new screw on connector for the mounting stud end for the new antenna?
Monty Posted March 18, 2010 #2 Posted March 18, 2010 Truck stop or CB shop should have what you need.
wes0778 Posted March 18, 2010 #3 Posted March 18, 2010 Truck stop or CB shop should have what you need. :sign yeah that: Got everything I needed at Flying J truck stop store
