latchkey Posted March 16, 2010 #1 Posted March 16, 2010 going to add raisers to handle bars 11/2 in do i need to take off faring?
SilvrT Posted March 16, 2010 #2 Posted March 16, 2010 nope check out this thread.... http://www.venturerider.org/forum/showthread.php?t=44815&highlight=baron+riser
latchkey Posted March 16, 2010 Author #3 Posted March 16, 2010 after reading all the post i`m sure i will have to fight the cables. maybe, just maybe i`ll be one of the lucky ones?
SilvrT Posted March 16, 2010 #4 Posted March 16, 2010 after reading all the post i`m sure i will have to fight the cables. maybe, just maybe i`ll be one of the lucky ones? I had no problems with the cables... guess I was "one of the lucky ones". As for installing the risers, just unbolt the handlebars and lift them up. Slide one riser in from the side, slide the other riser in from the other side, put the cap and bolts back on and tighten it down. The top bolts should be tightened before the bottom ones. Tighten the top ones to a "snug" fit and then crank the bottom ones down...then tighten a bit more on the top. (I believe that's the correct procedure).
SilvrT Posted March 18, 2010 #6 Posted March 18, 2010 thank you for your help You're welcome. Here's some pics when I did mine... [ATTACH]42895[/ATTACH] [ATTACH]42896[/ATTACH] [ATTACH]42897[/ATTACH] [ATTACH]42898[/ATTACH] [ATTACH]42899[/ATTACH] [ATTACH]42900[/ATTACH] [ATTACH]42901[/ATTACH] [ATTACH]42902[/ATTACH] [ATTACH]42903[/ATTACH]
