  latchkey said:
after reading all the post i`m sure i will have to fight the cables. maybe, just maybe i`ll be one of the lucky ones?
I had no problems with the cables... guess I was "one of the lucky ones".
As for installing the risers, just unbolt the handlebars and lift them up. Slide one riser in from the side, slide the other riser in from the other side, put the cap and bolts back on and tighten it down. The top bolts should be tightened before the bottom ones. Tighten the top ones to a "snug" fit and then crank the bottom ones down...then tighten a bit more on the top. (I believe that's the correct procedure).
  latchkey said:
thank you for your help
You're welcome. Here's some pics when I did mine...
[ATTACH]42895[/ATTACH] [ATTACH]42896[/ATTACH] [ATTACH]42897[/ATTACH]
[ATTACH]42898[/ATTACH] [ATTACH]42899[/ATTACH] [ATTACH]42900[/ATTACH]
[ATTACH]42901[/ATTACH] [ATTACH]42902[/ATTACH] [ATTACH]42903[/ATTACH]
