Cougar Posted March 14, 2010 #1 Posted March 14, 2010 (edited) Not sure why Hannigan does not have the Dealers or Hannigan them self's add this when doing the Rake Install . I have found that there is no way to adjust my headlight to to proper angle after the the rake has been added. After the rake kit is installed (my) headlight wants to shoot up into the sky. I finely got around to doing this as one of my winter projects this year. Here is my fix. The Picture below are standing in front of the bike, So I will refer the left and right in that manner. Picture (1) is both left and right NOTE: You will also need longer bolts to do this project. those should be laying around in a bag of nuts and bolts you got back from them removing all your other stuff. [ATTACH]42727[/ATTACH] Picture (2) is left - with a spacer that is 2.25 thick and a washer of .065 [ATTACH]42729[/ATTACH] Picture (3) is right - - with a spacer that is 3.00 thick and a washer of .065 [ATTACH]42728[/ATTACH] I did this mod a while back but never got around to testing it, I did this AM while it was still dark outside with the VRtech Headlight Adjustment write-up. http://www.venturerider.org/forum/showthread.php?t=1064 You will still be able to use the knob to fine tune your adjustments as well. My Findings where it was pretty much dead on, I also did my settings with the light on low beam to start with. then tested it with the high beam on. NOTE:: you will also have to re-adjust your running lights as well if you already have them installed. I think if you get close to my sizes it will still work or get you close. Any Questions feel free to email me. Jeff Edited March 14, 2010 by Cougar
bongobobny Posted March 14, 2010 #2 Posted March 14, 2010 Jeff, I will make SURE to bring it to their attention when I'm down there in 2 weeks...
Cougar Posted March 14, 2010 Author #3 Posted March 14, 2010 (edited) Bob, they do not do this mod , maybe have John look at this post when you get there. maybe they will start doing this for future rakes. but for now they do not do this. from what I understand, I could be wrong though. Another person to talk to would be Jim Gooch . (warranty guy) Jeff Edited March 14, 2010 by Cougar
kj5ix Posted August 6, 2010 #4 Posted August 6, 2010 Bob, they do not do this mod , maybe have John look at this post when you get there. maybe they will start doing this for future rakes. but for now they do not do this. from what I understand, I could be wrong though. Another person to talk to would be Jim Gooch . (warranty guy) Jeff NOPE still no word on such mod from them. I am going to have to do this myself this week end,,, Man you talk about in the clouds the light was off to the moon last night....and way Left..
Cougar Posted August 6, 2010 Author #5 Posted August 6, 2010 Yep, Just as you described. mine seems to be good to go the since I did the mod. you might be able to get away with half the space on each washer die. maybe? The light housing will stick out from the fairing a bit with the mod, but I can at least see the road now. Also make sure you get that trunk of yours FAR back or the little woman will not fit right. I also had to do that MOD as well.
kj5ix Posted August 7, 2010 #6 Posted August 7, 2010 Yep, Just as you described. mine seems to be good to go the since I did the mod. you might be able to get away with half the space on each washer die. maybe? The light housing will stick out from the fairing a bit with the mod, but I can at least see the road now. Also make sure you get that trunk of yours FAR back or the little woman will not fit right. I also had to do that MOD as well. ?????? Got me on that one,,, she is only 98lbs holding a sac of taters. She wants to come down a lot though, she isn't use to sitting so high,,, I have built a bunch of these in the last 14 months, but have heard nothing back from any of them except why did I wait so long..... I am sure that the light had to be out some,,,
Cougar Posted August 7, 2010 Author #7 Posted August 7, 2010 For some reason after installing the false rear fender to attach the the rear seat and wire cable brackets , If you do not place them in the correct spot your wife will be (pushed) to far forward. (make since?) What I had to do was move the trunk back and relocate the passenger seat has well. now it seems to be back to were it was when we had 2 wheels. I think the location of the trunk was a huge factor. just an FYI while you are building. the back of my trunk over hanges the lip on the trike body now. I had to use rubber washers off a shock , you can buy them separately. to give the right height for the lip. Jeff
Cougar Posted August 7, 2010 Author #8 Posted August 7, 2010 George, I have been wanting to ask you a Question.I had asked you why you had to take the entire rear end of the trike off to add the Aux gas tank. I am confused as why? why can it not still be connected to the front. I know the body must be removed and welding tabs has to be done. but still confused as why I need to remove the frame work to add the new tank? Thanks, Jeff
