SC89Venture Posted March 8, 2010 Posted March 8, 2010 Another newbie question. Are Venture's prone to getting gas in the crankcase like the Yamaha Virago's if the petcocks leak or do not shut off? Just checking for overall impressions. Thanks again Don
GigaWhiskey Posted March 8, 2010 Posted March 8, 2010 (edited) My guess is that it would not be common if it did happen. These are fed by an electical pump and is not gravity fed. The tank is under your butt between the frame. The petcock is right next to your right heel when sitting on the bike. Edited March 8, 2010 by GigaWhiskey
Squidley Posted March 8, 2010 Posted March 8, 2010 Don, I have never heard of a Venture flooding the cylinders because of the petcock. I have always kept mine on reserve and payed attention to the gas gauge. As mentioned it's not a gravity fed, you dont have anything to worry about.
BOO Posted March 8, 2010 Posted March 8, 2010 I never heard of one doing that either but the carbs are pretty high and I would think if the stars crossed just right it might be possible. It would take two or three things going wrong to make it happen. BOO
stardbog Posted March 8, 2010 Posted March 8, 2010 I would start with spark plug or coil. If one cylinder doesn't fire all the time, it's possible some fuel is washed down in to crank case. Don't ask me how i know . It's almost impossible to figure out if one cylinder doesn't work by ear, Indications are fuel milage is dropping down about 100 miles per gas tank, and bike doesn't go over 90 miles/hr. Good Luck.
eusa1 Posted March 8, 2010 Posted March 8, 2010 crap in the bottom of the bowl of one or more carbs and the float stuck in the down position. seen it several times. mike
CaptainJoe Posted March 9, 2010 Posted March 9, 2010 1. If your carb float has a hole in it it will fill up with gas and not shut off gas. 2. If dirt gets between the needle valve and the orifice in carb it will fill up with gas. There should be a clear plastic over flow pipe on each one of the carbs , have you noticed any gas under bike?
a1bummer Posted March 9, 2010 Posted March 9, 2010 I have an old Honda CB450 here that had plenty fuel in the crankcase after the P.O. put "Fancy" plugs into it and burned a hole into one piston.
GigaWhiskey Posted March 9, 2010 Posted March 9, 2010 I have an old Honda CB450 here that had plenty fuel in the crankcase after the P.O. put "Fancy" plugs into it and burned a hole into one piston. Now that I can see happening, lol.
