If I remember correctly there was a post at one time on how to build a wooden adapter on this forum. I built one the first time I owned my 2000 RSV and it worked quite well. However - after buying a Carbon One from a person on this forum - I agree - it is well worth the money. It provides tremendous stability as you lift your bike.
Cut some wood blocks to fit from a 2x4. It works fine enough for me.
Some folks do this and it does work, but spend the money for the Carbon One lift. I have had 3 of them and love them. 2 of them I gave away to friends with RSV's and they love them too
:happy34:
I made a square out of 2x2's to set on the jack while lifting it and I also strapped the bike down once I got to the desired height. I was able to move my bike around the garage while set up this way. The squre needs to be 17 inches by 13 inches and I used screws and wood glue for strength
hope this helped :smile5:
I am a retired heavy construction superintendent and now I have a remodeling business and do lots of carpentry. I (personally) would not trust 2x4's to lift my bike. There are varying grades of lumber and failure could occur. I did use hockey pucks but now I have the Carbon One and it will do the job efficiently with my Sears jack.
:farmer:
Initially I bought some steel " U " channel and fabricated a frame but even it wasn't as stable as the CarbonOne lift adapter. hmmmmm... maybe my fabrication expertise isn't so great...??? :rotf:
in any event, CarbonOne's adapter has, for me, been well worth the money.
2 x 4's ??.... personally I just wouldn't feel comfortable with that.
i have a motorcycle lift from craftsman, besides buying an adapter is there a easy way to lift bike safely?
I've been using the hockey puck method.
My mistake. :doh: I thought Carbon One was a retail brand name. Thanks for posting the link.
no problemo ... I can see where one might assume that.
Guest scarylarry
We could be friends too, got anymore?:rotf:
:happy34:
