After looking at this article ...
http://www.venturerider.org/forum/showthread.php?t=10518
and viewing this picture...
[ATTACH]42497[/ATTACH]
My friction plates are not lined up like that.
I did have a new clutch basket installed about
4 years ago. maybe the mechanic messed it up?
I noticed that on mine that are scattered all over the place ,there are
some plates with one notch and some with two notches.
any input on this guys?
Thanks,
Jeff
Time for a new mechanic !!
Always better when you can do it yourself.
It gives one a better understanding, and you really care if its done right.
Gary
This is the ONLY thing that I did NOT do.. myself.
As it was under warranty work for a (I) basket
change.
So.... What do I do? they should all be lined up correct?
And how come this has worked for the past 4 years this way?
Found the (..) Dots on the basket at 5 O'Clock..:D
I AM SO GLAD I DECIDED TO DO THIS MOD to find
out what a crappy job those mechanics did. I still
wonder why it work for so long?
I just like knowing the theory behind having them matched up :confused24:
At least it will be the right way now.
Steel Plates look real good as well, no glazing.
Can not wait to get my new parts!:happy65:
Several ways they can go togather and work. And some that they won't work at all.
I had done a bunch of them before I put one back in and it wouldn't work. Wasn't my bike and I was stumped. Had to call Squidley.
Just watch the notches when you take out and put them back same place.
Dan, there were no (2) Aligned up the same. ALL different directions.
*oops* Well now I gatta make them all the same as I have taken them off
already :whistling: But it did work this way for 4 years :confused24:
the old way of stacking plates was to never line them up because they where not perfectly
flat , you did not have a bad mech. just a old one :rotf:
Hey Thom,just read your tag line..
:snow::snow::snow:
Better not tell that to Scooter Bob.....:whistling: :rotfl::rotfl:
Also check the steel plates.
There is a very subtle difference between the outer edge profiles.
One will be slightly rounded, the other, somewhat what sharp.
You want the sharp sides all on the same side.
I haven't heard of a difference on which way overall stack off steel plates face, just that they are all oriented the same.
Gary
Gary, I was just going to ask that Question . THANKS
I did notice a sharp side and a rounded side. thinking of
placing the sharp side inward.
My Other Question am I screwed If I put the friction plates
in the right way now? Since I have no clue now how they were
before (all over the place) the Notches.
One more. Do I just Soak the new friction plate as the others
have already been oil soaked? How long DO I need to leave
the new plate in the oil for?
Thanks
Gary
It might be a good Idea to place the sharp Edges towards the outside of the Bike. Because this may cause, if at all, minimal Binding when the Clutch Lever is pulled, but it ensures the best Movement possible when the Clutch Lever is released and the Clutch should bite.
Thanks
No, you're not screwed, but place them Notches like it's described in the Shop Manual. It's a balancing Thing.
Yes, soak the new Plate in Oil, i prefer to have them in Oil over Night.
Thanks
I just looked at the manual back to the 83-85.
Service manual indicates to align the notches.
I am guessing you don't know how they were in prior to your disassembly, So I would think they should be put in as per manual.
Any other way would probably be a crap shoot.
:2cents:
Gary
Yeah, It was kind of hard to figure out witch one was where when
pulling them off and tring to keep them in the same. like I said there
was not one of them was the same, it was like a bad rubics cube :D
