eusa1 Posted March 6, 2010 Posted March 6, 2010 the dealership usually twist them really hard before you leave the store:rotfl::080402gudl_prv:sorry if it hurts too much?
KeithR Posted March 6, 2010 Posted March 6, 2010 Nothing worse than losing a nut! Here's my .99 solution Keith http://www.venturerider.org/forum/showthread.php?t=27341&highlight=lost+seat+hold
Oldslow Posted March 6, 2010 Author Posted March 6, 2010 Well thanks Keith Rose...Nice to see another Newfie on the board...I hail from Baie Verte myself and my wife is from Glovertown. I'm considering a couple of tight fitting chunks of hard rubber tube to turn on over those studs.
warthogcrewchief Posted March 6, 2010 Posted March 6, 2010 I hear there's a procedure to reverse the damage.
Cougar Posted March 6, 2010 Posted March 6, 2010 And I woke up from a wonderful NAP, to read this stuff? OH MY!
Cougar Posted March 6, 2010 Posted March 6, 2010 I am VERY happen with my NEW nuts! thank You Very Much! http://www.venturerider.org/classifieds/showproduct.php/product/1663/cat/7 As you will be also! Good Luck with you new nuts. I have not lost one yet since I switched over! Jeff
dmoff1698 Posted March 7, 2010 Posted March 7, 2010 Accidentally or on purpose? I have lost my left seat nut twice now!! Both times I found it jamed between the starter and the transmission!!!!!!! Lord knows how long it had been riding there. It was just luck that I saw it the first time, the second time I knew where to look.
Monty Posted March 7, 2010 Posted March 7, 2010 I lost a nut this morning too....I thought that was a good thing.
Chaharly Posted March 7, 2010 Posted March 7, 2010 We used to have a teacher that had a replacement nut. Damn dealership made it out of rubber!!! The sad thing is that im not kiddin, he only actually had one
Mike G in SC Posted March 13, 2010 Posted March 13, 2010 Hey, a FYI: If you ever loose your shifter bolt on the run, the side cover dummy bolts will do the trick till you can reorder a new one. (and use some Loctite) If you already know this it's because you once said "HOLY S*&%" when you started to downshift and your whole shifter flopped down on your floorboard.
RedRider Posted March 14, 2010 Posted March 14, 2010 Hey, a FYI: If you ever loose your shifter bolt on the run, the side cover dummy bolts will do the trick till you can reorder a new one. (and use some Loctite) If you already know this it's because you once said "HOLY S*&%" when you started to downshift and your whole shifter flopped down on your floorboard. BTDT. Figured it out on my own under the lights of a toll booth in Oklahoma. I was certainly a pucker moment when I went to downshift and there was nothing there. RR
