:no-no-no: :no-no-no: No., No , No .... not them there nutts , but the scoot's seat nuts .:rotf::rotf::rotf:
Having heard people talking about being able to take the scoots seat off for multiple reasons , wing nuts vibrating off and loosing them , or not being able to access a wrench easily . So I did the same thing like I did for my saddle bag bolts .
Using the original nuts off the stock seat , I drilled a hole completely through the bottom of the 2 seat nuts using an 1/8" bit . I took an 1" stainless steel split ring (like used on key rings) and threaded one through each holes of the each nut . Then I took a stainless steel 10" fishing leader (one end has swivel and other end a snap hook) and thread the swivel end into one of the split rings on one of the nuts . Then I re-attached the nuts back onto the seat , then thread the fishing leader over to the other nut and connected the snap into the other split ring/nut .The leader prevents the nuts from backing off . Cost was only a few dollars and took about 15 minutes to make .
Here's a photo .
BEER30
I have seen something like that before, but that aint what they were used for........:rotf::rotf::rotf::rotf:This is a PG rated site, so I aint saying what they were used for ...................:rotf::rotf::rotf:But I will say they were a form of ladies jewelery!!!!!!!!!!!!
Where did you get that idea? Looks like a nipple ring. I am using wing nuts 6 X 1.00 MM. So far they haven't backed off. However, keep giving up those creative ideas.
MIKE aka Uturn
Gene I am so sorry to hear about your horrible accident. I only hope that I can find a Hallmark for this problem. I would suggest sitting in a nice warm tub of water.
Mama:confused24:
Mama:confused24:
But Mama , they would rust ! Where's a Nurse when ya need one ?:rotf::rotf::stirthepot:
If someone suggests kissing them to make them better the PG rating might just get revoked! :no-no-no:
Man, you sure know how to get a guy's attention!
Paul
Gene,
I removed the two stock steel nuts.
Then installed two plastic nuts of same size........
They both thread on by hand, they dont vibrate off, and are easily removed by hand....no tools required......
