screaming red Posted March 6, 2010 #1 Posted March 6, 2010 (edited) Hi to all, Just had my rear tire replaced and something does not look right. I remember seeing a nut and lock ring on the right swing arm, can't be sure but not feeling safe riding. Any help would be appreciated. Screaming red Edited March 6, 2010 by screaming red
Guest scarylarry Posted March 6, 2010 #2 Posted March 6, 2010 Can you look at the manual and see if all was done right? You might have to re-do the installed from the beginning to make sure it was done right, there is a downlaod for the manual here...in the tech section
milkman Posted March 6, 2010 #3 Posted March 6, 2010 Hey Red Looks ok to me, Only difference I see is pinch bolt has been changed & flat washer added. Larry:thumbsup2: good to go:Venture:
aharbi Posted March 6, 2010 #4 Posted March 6, 2010 Just a suggestion. But you may wish to sign up for My Yamaha. It's free but allows access to the parts catalogs. Where you can see the exploded views of the bike parts. It may help. http://www.yamaha-motor.com/sport/myyamaha/home.aspx
screaming red Posted March 6, 2010 Author #5 Posted March 6, 2010 Hey Red Looks ok to me, Only difference I see is pinch bolt has been changed & flat washer added. Larry:thumbsup2: good to go:Venture: Just wanted to make sure, I just remembered a bolt on that side. Screaming Red
Snaggletooth Posted March 6, 2010 #6 Posted March 6, 2010 Pretty much looks like this one and the washer is in the right spot. Pinch bolts stand out.
Dano Posted March 6, 2010 #7 Posted March 6, 2010 It's not done right, the swingarm should be up against the brake mount, the washer needs to go against the hub. Here's a couple pics of what it should look like. I know mine doesn't look the same, but this is off a MKII and my MKI looks the same, 'course I don't know what bike you've got.........
MiCarl Posted March 6, 2010 #8 Posted March 6, 2010 (edited) It's not done right, the swingarm should be up against the brake mount, the washer needs to go against the hub. Here's a couple pics of what it should look like. I know mine doesn't look the same, but this is off a MKII and my MKI looks the same, 'course I don't know what bike you've got......... No, No, No. The washer goes between the caliper carrier and the swingarm, just like it does in your pics. On a stock 1st gen that washer ends up being pretty close to the swing arm. If you put the washer against the hub the brake caliper is not located properly on the disc. Everything stacks up from the left. The reason for the shoulder on the axle is to pull the washer against the caliper carrier - which positions the caliper centered over the disc. That side of the swing arm has a clamp (instead of a nut like on your bicycle) to allow some variation in the parts without binding stuff up. The OP appears to have a 2nd gen. Not sure if the position is correct but the parts are in the right order. If it's too far to the left the problem is over at the final drive. BTW, I have a 2nd gen final drive on my MKII. That results in the wheel moving about 1/4" to the left. So, I have a noticeable gap between my swing arm and that washer. Edited March 6, 2010 by MiCarl
Dano Posted March 6, 2010 #9 Posted March 6, 2010 OK, I stand (or sit rather!) corrected on the washer, I've just never seen that much gap between the carrier and the swingarm.
MiCarl Posted March 6, 2010 #10 Posted March 6, 2010 Yeah, it's tight enough on a 1st gen that they've got an angle cut onto the swingarm so you can cram it in.
screaming red Posted March 6, 2010 Author #12 Posted March 6, 2010 Thanks for all your replies and sorry I should have put second gen in my posting. Its 10 degrees today in Ontario Canada and looks like great riding weather. Have a great day guys. Sreaming Red
