dingy Posted May 7, 2011 Author #26 Posted May 7, 2011 Below is a cut & paste of the info I have regarding the company I got the crystals from. I have had my brake master in since last spring. Crystal is still very clear and no leaks. The one issue I had was some softening of the clutch side epoxy where it was on to thick. This new idea for an adhesive may work better. I used 17.5 mm crystals x 2mm thick I did not hone the bores as I couldn't find a hone that would fit . Gary Company name is: Esslinger & Company http://www.esslinger.com/ Jewelers Glue Vigor Jeweler's Epoxy 12.0451 1 $3.95 $3.95 Watch Crystal Round Mineral Glass Crystal x 2.5MM Thick MM / Diameter : 17.5 201250 3 $2.95 $8.85 Subtotal: $12.80 Shipping & Handling: $8.30 Tax: $0.00 Order Total: $21.10
thor68372rockon Posted May 7, 2011 #27 Posted May 7, 2011 @ dingy, Hey, Thanx Alot For The Info dingy!!! Will Order Some Crystal Lenses Today Hopefully. Was Just Going To Put A Metal Electrical Box Slug In There And Spray A Ton Of Coats Of That Permatex Sealer Over The Darn Thing Just To Make Sure It Didn't Leak. I Usually Check All The Fluids Every 3-4 Days Any Way, So The Sight Glass Is Pretty Much Useless To Me Any Way. Thanx For The Info Again! Thor68372rockon:sign Rock On:
Bassett Posted December 26, 2016 #28 Posted December 26, 2016 dingy said: Would anyone be interested in the purchasing of replacement sight glasses for the Brake & Clutch master cylinders? I know that there are some of these that have discolored or leaked in these older bikes. I have just finished replacing both of my sight glasses with a mineral glass watch crystal. I wanted to powder coat my master cylinders. To do this, I needed to remove the sight glass as it would not take the heat of the curing process. In doing so, I destroyed the sight. I have replaced both of these now with the watch crystal. I used quick setting jewelers 2 part epoxy to bond into housing. I had to buy 3 crystals & the epoxy to meet suppliers minimum order. I have had the extra crystal soaking in brake fluid for several days now. It shows no signs of discoloration. If I could do a bulk purchase, it would cost $12.00 for two crystals, including shipping to you. If you wanted, I could also get the two part epoxy for another $5.00. I know these work on 1st gen bikes, but I am not sure about 2nd gens. The crystal I used is 17.5 mm dia., & 2mm thick. 1st picture is of old sight removed & O ring that is under it. 2nd picture is of installed crystal. Let me know if interested. Gary Still have them available?
