Yep, all what is stated above. and also lets say my bike is stuck on the side of the road. and I want my flashers to stay on for a long time. they will not , if my headlight is turned on as well. (drained battery)
My success story is that I am done. the tiny blinking LED's are on each side of the key mounted on the top tank bezel. (blinking red) when my toggles are off on my running lights and headlight they are separated from each other. If I ever forget to flip my toggles on after working on somthing There is no way now that I will not know both headlight and running lights are OFF before I begin my riding ventures.
I have noticed after all my wiring this last winter, it has been nice to be able to have my headlights and running light off while doing all my stuff.
Note: BOTH Headlights and Running lights are off relays now keeping my
wire harness from any harm in the future I hope.
Thanks Everybody!
Jeff
  • Replies 53
  • Created
  • Last Reply
Top Posters In This Topic
Scott, I will shoot some pics this week for ya.
Letting some silicon dry and added some plugs
to all the stuff so I can remove my tank/ ignition cover
easy. my garage door opener button, switch for LED's under tank
and the two small LED's for what was talked about in this thread
are all on that pod, and it can now be removed with ease . for
removal of tank. I also have a quick disconnect for the LED's
under the tank as well.
Jeff
Here are some pictures of what I was after in the long run.
Garage door opener (small button) Other switch for
LED's under tank. and the (2) Blinking Red LED's by the Key Hole.
Just plug them in and all works great.
[ATTACH]42267[/ATTACH]
[ATTACH]42268[/ATTACH]
[ATTACH]42269[/ATTACH]
