showmebob Posted February 24, 2010 #1 Posted February 24, 2010 Dont understand this at all, it will idel but when you give it the gas it just bogs down Put the beather back on and it is fine
Squeeze Posted February 24, 2010 #2 Posted February 24, 2010 That's normal for all these V4 Engines. The Airbox/Intake is a very sophisticated and the System won't work when it's incomplete.
showmebob Posted February 24, 2010 Author #3 Posted February 24, 2010 Gess Yamaha has it down to a natts A**, never had one do that before. Hey where can a guy get a good air filter, this is how this hole thing started
Snaggletooth Posted February 24, 2010 #5 Posted February 24, 2010 You can go stock OEM for about $40.00, K&N for about $55.00 or more or go inexpensive with a EMGO for about $19.00. I use the EMGO and it works fine. Fits like the stock filter. I forget the part number. Google will show you the way.
showmebob Posted February 25, 2010 Author #7 Posted February 25, 2010 You can go stock OEM for about $40.00, K&N for about $55.00 or more or go inexpensive with a EMGO for about $19.00. I use the EMGO and it works fine. Fits like the stock filter. I forget the part number. Google will show you the way. Thanks I will check that out
warthogcrewchief Posted February 25, 2010 #8 Posted February 25, 2010 I just ordered my EMGO filter from bikebandit.com and got it in this evening! You can get them from Bike Bandit.
raceman62race Posted February 25, 2010 #9 Posted February 25, 2010 Dont understand this at all, it will idel but when you give it the gas it just bogs down Put the beather back on and it is fine It uses the negative pressure caused by the airbox to pull gas out of the carb bowl. Most bikes are designed that way. If you really want to run it with the airbox off, you can get a couple of pieces of heavy cardboard (and maybe a friend to help) and lay it accross the top of the carbs air intake. You'll find a spot where it will fun fine. The cardboard will create the negative pressure caused by the airbox when it is installed. I use to own a Suzuki VL 1500. One popular mod to gain power was to remove the restrictor on the inlet side of the airbox. In doing so, you had to dramatically increase the jets and needle setting to compensate for the pressure loss because of the larger intake hole in the airbox. Hope this helps.
