Since I could not load the bikini side panel pictures on your PM, I will try it here.
I cut the bottom section to the length I wanted and then used a heat gun to soften the plastic to bring it to a point. I then used Devcon Plastic Weld to fill and very little body filler to smooth it out. I also narrowed the top section some to make it blend with the fairing better.
I hope this helps some.
RandyA
Whew !!!
I thought we were getting kinky.....
I thought we had a winner for the Great VR Scavenger Hunt.....:happy65:
The current target is.....
You and your bike with a beach in the background. Prefer warm and sunny with sand and blue water, but so everyone can play, I will settle for hard water and snow covered sand as well. Have fun with it...
BONUS...I'll buy you a beer at the international if you're wearing your (or anybody else's) swimming suit. by Scooter Bob
Body work looks great by the way.:sign kewl:
Later, Scooter Bob
:Venture:
Randy , i think that it is a bad idea doing that to your bike ! it opens the motor so you can see more and it keeps it cooler [ looks and temp ] and if you remove the rubber air dams , it keeps your legs cooler like i said a bad idea ! so in the end keep coming up with the bad ideas ! i am glad you showed me how to do it at Vogel many moons a go , Dindy , you need to check out his lites to !
by the way a big thanks Randy :thumbsup:
