I saw a comment somewhere about making your own exhaust seals on the first gen out of copper wire. Can somebody expound upon this please? It sounds ingenious.:Venture:
If your gaskets (where the rear downtubes meet the stubs off the rear head) are thin, you can take one wrap of #10 solid copper wire around the pipe next to the gasket and it'll help seal it up. All it's doing is taking the place of the gasket material thats not there. I don't think it'll work without a gasket in there, of course it will take more turns to replace the missing material. Worth a try, tho.
Good luck
Now I'm thinking some lead. You can shape it exactly. I don't think it will get hot enough to actually melt and run out or weld things together. :Venture:Of course, if the weather breaks it won't happen at all!
That's what I did with mine. Just cut a length of #10 copper wire the right length to make the gasket and then flattened it somewhat with a hammer and anvil, and put in place. I did mine in 2006 and so far they are still working great.
Exhaust temps at that joint can run up to 400 degrees!
