mdj6j Posted February 23, 2010 Posted February 23, 2010 I have a 2000 royal star venture and the clutch is slipping in 4th and 5th gear. When you get on the gas real hard. Changed clutch fluid. And it's still slipping. I have about 65,000 on the bike. Don't ride that hard. And no passenger (she rides her own) Where should I start with the spring plate or clutch disc. thanks Michael
Tom Posted February 23, 2010 Posted February 23, 2010 with that many miles I would do both..PCW racing has the kit and 30 minutes and you are done.
pick Posted February 23, 2010 Posted February 23, 2010 Yup, PCW's the way to go. Did mine about 15k ago, runs stronger than stock!
Sylvester Posted February 23, 2010 Posted February 23, 2010 I vote PCW and replace it all. If you can, bead blast the plates between the discs.
2Whlsrollin Posted February 23, 2010 Posted February 23, 2010 Just did mine a couple weeks ago with V7Goose's help. It was easy as folks say it is. Call PCW racing and order the clutch spring upgrade kit which consists of a gasket, spring and 1 friction plate to replace the weenie plate installed by Yamaha. It is the last plate and is a 1/2 plate hence the name weenie. They will try and sell you the rest of the plates as well but pass on that, just order the kit. Mine works like a champ now.
V7Goose Posted February 23, 2010 Posted February 23, 2010 LOTS of discussion here about this - just do a search on "clutch upgrade". As stated above, the PCW upgrade spring is the way to go, but replacement friction plates are almost never needed. Goose And welcome to the board - hope you hang around. You'll find out way more about htat bike here than anywhere else.
Flyinfool Posted February 23, 2010 Posted February 23, 2010 (edited) Just did mine a couple weeks ago with V7Goose's help. It was easy as folks say it is. Call PCW racing and order the clutch spring upgrade kit which consists of a gasket, spring and 1 friction plate to replace the weenie plate installed by Yamaha. It is the last plate and is a 1/2 plate hence the name weenie. They will try and sell you the rest of the plates as well but pass on that, just order the kit. Mine works like a champ now. I ordered my spring upgrade kit from PCW (Only because SkyDoc_17 had not started selling them yet) and wanted to also order the friction disks, they told me to wait till I have it apart and to check the plates because they almost never wear out. there is no cost difference other than the extra postage to get the plates later if mine are worn. For my 1st gen, (not sure if the 2nd gen is the same) the friction disk dimensions are 3mm (.118 inch) thick when new and the replace dimension from the manual is 2.8mm (.110 inch) thick. with 45K on my clutch the plates measured 2.95mm (.116 inch) thick, so I reused them. Edited March 15, 2014 by Flyinfool
dingy Posted March 15, 2014 Posted March 15, 2014 How much was the kit? Link 2nd Gen kit in classifieds Gary
