Kuryakyn ISO grips
First_N_Last
Well I installed my 6235 ISO grips. Biggest difficulties were getting the bullet end cap weights off without scratching them & modifying the grip ends to enable use of the OEM end caps.
For getting the end-caps off -
wrapped the outside of the caps with 6 layers of duct tape
then used a strap wrench to break them loose to unscrew
found grunting & vulgarity quite helpful
For opening the ISO grip end to fit the OEM end-cap -
I started grinding out the hole with a Dremel tool...
that was taking forever!
went to Harbor Freight & bought $15 Step-Drill
then drilled out the holes to 1 inch easily
cut a brass pipe for the spacer on the throttle side
Only remaining problem is that the throttle is a little sticky. I'll take it apart & fix that another day.
The grips are great & look really nice with the OEM end-caps on.
johnb
