frankd Posted February 21, 2010 #1 Posted February 21, 2010 I pulled the drive shaft out of my shaft unit. Lots of moly grease on it and everything looked great. The seal I bought is the correct part number ( 93108-43013-00), but when I slide it onto the drive shaft it slides over the area that the snap ring and washer go but it 'appears' that it's inner diameter is too small to go over the flat spot that the old seal was on. Does it stretch that much?? It seemed like the old seal was glued to the driveshaft. What glue are we supposed to use?? Frank D.
frankd Posted February 22, 2010 Author #2 Posted February 22, 2010 Mystery solved!! I cleaned up the shaft, got it under a bright light, and then a co-worker said "That looks like a repair sleeve". That made me realize that it actually was the inner 'race' of the old seal and needed to come off. Now the seal will slide on to where it belongs. Frank D.
