6pak Posted February 19, 2010 #1 Posted February 19, 2010 (edited) Deleted- see new post Edited February 20, 2010 by 6pak
Squeeze Posted February 20, 2010 #2 Posted February 20, 2010 Normally, if there's something wrong, there should Coolant seeping out of the Covers. Those are Water Jacket Drain Plugs, or Safety Plugs, if you like the Term better. If you have actual Oil coming out of there, I'd check for Coolant in the Engine Oil and for Oil in the Coolant first. Then go from there. Normally, it's changing the Plugs, top off Coolant and go for a ride.
Dano Posted February 20, 2010 #3 Posted February 20, 2010 Hey Lutz, I thought the same thing too till I looked again,,,,,,,,, That's the drain hole for the spark plug well, I changed my post in the other thread before someone could discover the error of my ways.......... The head coolant drain plug is below the cover attachment screw
