6pak Posted October 5, 2007 Share #1 Posted October 5, 2007 As usual, the moneypit is giving me grief again. This time, I'm trying to change the seals in the front forks. Got the wheel, fender and all off. I'm down to where I'm trying to break loose the 10mm allen on the bottom of the forks. The bolt just spins. Muffinman said that a couple of the guys from WV have made a tool that they use to replace what yamaha calls their "t handle for tightening and loosening the front fork holding bolts." When I looked in the shop manual, this thing looks like a really long 3/8 drive extension. If so, I can probably put one together. The next question is what size socket goes on the end, and do I need to worry about the outside diameter fitting down inside the tubes? Waiting on a little feedback here as at the moment I'm at a standstill. Link to comment Share on other sites More sharing options...
Black Owl Posted October 5, 2007 Share #2 Posted October 5, 2007 I believe that it is a 17mm allan............ Link to comment Share on other sites More sharing options...
Thom Posted October 6, 2007 Share #3 Posted October 6, 2007 if it the 1 i am thinking about , it the allen head at the very bottem of the tube , i used a impact gun and spun it out . Link to comment Share on other sites More sharing options...
cimmer Posted October 6, 2007 Share #4 Posted October 6, 2007 check this out in the tech library http://www.venturerider.org/forum/showthread.php?t=6875 I think that will answer your question. Rick F. Link to comment Share on other sites More sharing options...
