I got 2 led 1157 bulds for my scoot and decided they are better then i expected.I am going to hold off on the turn lights because the load change on the flasher. I did see you can buy the adapter to get more load but not sure where to put it. Also not sure if i need 1 or 2 load adapters. Any idea thanks Doug
that is suppose to be light not tight
Hi, I'm BubbaT, I'm new to this so help me out, what brand bulbs did you buy? I see there are several out there. Are you'res grounded with the extra wire or standard plug and play?
if you are considering LED turn signals...I recommend them.
I tired some of the repalcement LEDs Bulbs at first and took them out cause they did not appear to be much brighter than the stock incandescent bulb.
Check this thread for some information on this
http://www.venturerider.org/forum/showthread.php?t=30967
I would also recommend the LED tail/brake lights...
All my stuff came from http://www.customdynamics.com/ They have everything you need. They have Turn signals kits for front and rear with load equalizers.
http://www.customdynamics.com/yamaha_turn_signal_retro.htm
Tail/bake lights with 100 LED's that will blind you.
http://www.customdynamics.com/Yamaha_tail_retro.htm
They have a good tech support so if you get in a mess...call them. They are not hard to install and get working.
:thumbsup:
These are 1157 base with the 36 LED bulbs on them. I started my scoot the other day and this time it shows a burnt out light on the computer. So i will have to ge the load adapter to keep them in.
