Sideoftheroad Posted February 7, 2010 #1 Posted February 7, 2010 Would there be any advantage to having both a volt and amp gauge? If not, which would be better to have?
dingy Posted February 7, 2010 #2 Posted February 7, 2010 Here is a very similar thread from last week. http://www.venturerider.org/forum/showthread.php?threadid=44985 My preference would be a digital voltage gauge. Amps don't tell you a whole lot about electrical system health. It is just an indication of current flow at the particular point in the system that the gauge was inserted at. Readings will vary at any given time depending on accessories running. You cannot run starter current through 99% of available gauges, so it has to be installed after starter motor circuit. Amp gauge somewhat more involved install. Gary
Ponch Posted February 7, 2010 #3 Posted February 7, 2010 I use a digital volt meter and an anilog ammeter.
KiteSquid Posted February 7, 2010 #4 Posted February 7, 2010 I would like to have both, but I am a geek for data....
