2Whlsrollin Posted February 6, 2010 Posted February 6, 2010 Has anyone installed these. I have a friend who did and I noticed a couple of the LED lights burned out. Was wonder about the quality. http://www.customdynamics.com/Yamaha_tail_retro.htm
MikeWa Posted February 6, 2010 Posted February 6, 2010 http://www.venturerider.org/forum/showthread.php?t=44987
ronhenry4 Posted February 6, 2010 Posted February 6, 2010 i put the same tail light in over a year ago and dont have any problems with it
Cougar Posted February 6, 2010 Posted February 6, 2010 there awesome, Hannigan put two of them on the trike. used one of the originals and placed the guts into it. nice and bright.
stroker ace Posted February 6, 2010 Posted February 6, 2010 I have one along with some of their led products, no problems. They stand behind their product I'm sure they would fix it if you had the time to mess with it.
midnite Posted February 6, 2010 Posted February 6, 2010 I have one on ours, great investment. Alot brighter than stock day or nite. Never had a problem with it. It does have a lifetime warranty if I'm not mistaken. Get in touch with the company, I'm sure they will make it right:thumbsup2:
CMIKE Posted February 6, 2010 Posted February 6, 2010 Great products from this company. I first bought the 32 LED tail light...and added a strobe unit to it.. This was a really bright tail light...50 times better than stock. Plug and play... See this video in this thread... http://www.venturerider.org/forum/showthread.php?t=32917 Then they came out with the 100 LED tail light. I just had to have it... So I sold the 32 LED and purchased the 100 LED... Now it is 100 times brighter that stock. I would highly recommend it. Money well spent since the RSV really needs some more lights on the back end.
Bummer Posted February 6, 2010 Posted February 6, 2010 I have the older 128 LED model. Going on 40k miles and four years now. So far I've had no issues with quailty. The web page mentions a lifetime limited warranty against LED failure.
2Whlsrollin Posted February 7, 2010 Author Posted February 7, 2010 Ordered mine last night. Thanks for the reply's.
N3FOL Posted February 7, 2010 Posted February 7, 2010 You won't be disappointed with the LED lights. As everyone has said, very bright backed with a lifetime warranty. Regards.
Cougar Posted February 7, 2010 Posted February 7, 2010 Now if they only would make a small round one to fit the front blinkers in Amber, now that would be GREAT! OMG, they DO! *LOL* http://www.customdynamics.com/yamaha_turn_signal_retro.htm
KiteSquid Posted February 7, 2010 Posted February 7, 2010 I have the 100 LED board and I like it. Now if they would make 9W LED turn signals for the front and rear......
N3FOL Posted February 7, 2010 Posted February 7, 2010 I really want Custom Dynamics to make a really nice & bright side marker. Didn't really like what J&P Cycles sell in their website that is why I have not done anything in that arena.
Cougar Posted February 7, 2010 Posted February 7, 2010 KiteSquid, witch ones do I use for the front? and do I need the equalizer thing? 1156/ 1157 ?
Bummer Posted February 7, 2010 Posted February 7, 2010 Get the Eclipze LEDs. 1157 for a 2000 model, I believe (two locking pins). I think the BAZE (three pin bulbs) started with the '04 year, but I'm not absolutely positive. 1156 for the rear. You do not need load equalizers unless you really want them. The lights flash a bit fast, like having a burned out bulb. It gets attention, which is the pretty much the point.
Cougar Posted February 7, 2010 Posted February 7, 2010 So these are the one's then. Eclipze LEDs. 1157 Thanks Bummer.
2Whlsrollin Posted February 12, 2010 Author Posted February 12, 2010 I received mine and installed it last night. Wow sure is bright,should have done this awhile ago.
Cougar Posted February 12, 2010 Posted February 12, 2010 Did you do the front or the rear? Did you add the load thingy as well?
2Whlsrollin Posted February 13, 2010 Author Posted February 13, 2010 No so far I have just done the back. Have been reading the posts about adding the front as well.
