CrazyHorse Posted January 31, 2010 #53 Posted January 31, 2010 Can you machine out the valve adjustment tool? Id love to have one.
Sylvester Posted January 31, 2010 #54 Posted January 31, 2010 I need two, please. Do you have them for left handed people?
CMIKE Posted January 31, 2010 #55 Posted January 31, 2010 I will take one. LEt me know where the Paypal should go... Thanks
Condor Posted January 31, 2010 #56 Posted January 31, 2010 Yeah, put me on the list too. Gawd, I love group buys.....
lonestarmedic Posted February 2, 2010 #59 Posted February 2, 2010 I would like 2 of these. It should make holding the lower nut easier while tightening down the upper nut against a "Furber fix" washer. I can then make torque adjustments and truly see what happens to the dreaded steering shake. Let me know on the Paypal. Anytime you are ready. J. B. Floresville, Texas
StuD Posted February 2, 2010 #60 Posted February 2, 2010 Count me in I'll take one for the West Coast :canada:
KB2RWW Posted February 2, 2010 #61 Posted February 2, 2010 IF the prototype works well for you, Put me down for one also. Will they all be in stainless or can we get them in steel? I may want to Nickel plat mine. yours will be better to use than for me to draw one up in master-cam and cut it out on the water-jet.
dingy Posted February 2, 2010 Author #63 Posted February 2, 2010 KB2RWW said: IF the prototype works well for you, Put me down for one also. Will they all be in stainless or can we get them in steel? I may want to Nickel plat mine. yours will be better to use than for me to draw one up in master-cam and cut it out on the water-jet. All wil be 304 Stainless Steel. Might be able to powder coat though for an up charge. White, Black, Red or Yellow Gary
wolfman1 Posted February 4, 2010 #65 Posted February 4, 2010 I'd be interested in one as well. Thanks Steve
KiteSquid Posted February 4, 2010 #66 Posted February 4, 2010 KiteSquid said: IF the prototype works well for you, Put me down for one. Can I up my order to two?????
dingy Posted February 4, 2010 Author #67 Posted February 4, 2010 (edited) I was in contact with my supplier on Wednesday 2/3/10. They wanted $75.00 to do a 1 piece prototype for me. This was quite a bit higher than I was expecting. They agreed to set up to run my order quantity, and allow me to inspect the first piece off of that run at no additional cost They are going to call me prior to setting up to run and I will go to plant. Its about 25 minutes from here. If first piece is acceptable I will get order at that time. If first piece is not acceptable, I will make design modifications and reschedule. I will incur one time piece charge if this happens. The order acknowledgment says they will run order by 2/12/10 One other slight change is the material was to be mill finish 1/4" stainless steel., They had a piece of brushed 1/4" stainless steel in stock that parts are going to be run on. I am not sure if this is brushed on one side or both. This will make a nicer looking finished product. It will complicate my cleanup somewhat though. A laser burner produces a small amount of slag on the downside of sheet being burnt. I was just going to touch this surface to my stationary belt sander to clean up. May have to come up with plan B Gary Edited February 4, 2010 by dingy
capn eddie Posted February 4, 2010 #68 Posted February 4, 2010 dingy said: I was in contact with my supplier on Wednesday 2/3/10. They wanted $75.00 to do a 1 piece prototype for me. This was quite a bit higher than I was expecting. They agreed to set up to run my order quantity, and allow me to inspect the first piece off of that run at no additional cost They are going to call me prior to setting up to run and I will go to plant. Its about 25 minutes from here. If first piece is acceptable I will get order at that time. If first piece is not acceptable, I will make design modifications and reschedule. I will incur one time piece charge if this happens. The order acknowledgment says they will run order by 2/1210 One other slight change is the material was to be mill finish 1/4" stainless steel., They had a piece of brushed 1/4" stainless steel in stock that parts are going to be run on. I am not sure if this is brushed on one side or both. This will make a nicer looking finished product. It will complicate my cleanup somewhat though. A laser burner produces a small amount of slag on the downside of sheet being burnt. I was just going to touch this surface to my stationary belt sander to clean up. May have to come up with plan B Gary i think plan B should be that you send us the tool and we could clean that edge up, saves you time and labor. just my thoughts, what does everyone think.
dingy Posted February 4, 2010 Author #69 Posted February 4, 2010 I just talked with shop foreman from my supplier. He is going to go ahead and run the sample piece for me tomorrow morning, Friday, 2/5/10. I will not apparently be charged for this one piece sample. He seemed more willing to work with me than salesman did. He indicated his laser scheduling is tight right now, so it would be into next week before I get full run. I will let you know tomorrow about status and some pictures. Gary
Freebird Posted February 4, 2010 #70 Posted February 4, 2010 I also don't care about the finish. It is is brushed on one side and bright orange on the other I could care less. So long as it works.
LilBeaver Posted February 4, 2010 #73 Posted February 4, 2010 Freebird said: I also don't care about the finish. It is is brushed on one side and bright orange on the other I could care less. So long as it works. don't get me wrong, I like my tools and I am easily distrac... *ooo shiny object*.... ted by shiny objects. But function is my concern.
dingy Posted February 4, 2010 Author #74 Posted February 4, 2010 rjalamo said: Ahhh, could I get mine pink please!! Maybe, I just got a used oven for in my garage. I am going to get the powder coat set up that harbor freight has for $69.99. [ATTACH]41056[/ATTACH] Gary
1joeranger Posted February 4, 2010 #75 Posted February 4, 2010 If you do, I'll be the envy of the tool world! Well, maybe that's not the right adjective!! Thanks so much for your time and effort on this!
