I know that the factory toque's the ignition bolts down and brakes them off at the factory if my thinking is correct. So my Question is how are some of you removing them.
The only reason I want to do this and remove them and place a regaler bolts on there place is I have a spare and if one day I was stranded I could just replace it on the road
and be on my way. any idea's or tricks that you folks have done to remove them?
Is it a hard job? I guess worse case is I could pull tank back a bit and un-plug bad iggy
and plug now on in leave it lay there .. under the tank.:scratchchin: all I am doing is thinking ahead a little for long road trips. even have my spare fuel pump as well.:)
Thanks!
Jeff
I used a dremel to cut slots in the round heads then used an impact driver to remove the bolts. Note: they are loctited in place so dont be afraid to whack that impact driver hard. You can get replacement bolts from any hardware store. The bolts that hold the handlebar risers on are the correct size and length.
drill a small hole into the center of the screw and put an easy bit out into the hole.
that what i did on 3 bikes.
mike.
do you have a spare ignition switch?
mike.
Not doubting you on the EZ out but I tried it and all I did was snap off the bit in the hole. The loctite had a death grip on my bolts.
I tried the ez out. It worked on one side, but rounded out on the other. I drilled the head off with a larger bit and still had to take the dremel to it.
How long is that bolt on each side guys?
Mike , yes I have a spare spare ignition switch now.
and what did you guys replace them with? what MM size?
And another Question, why are you guys taking those bolts out as well? same idea?
jeff, you may want to split the new ignition switch in advance of any failure, so that you can key it to match. its very easy, the screws are also anti theft style.
Mike,
I will just bring it to your house this summer and you fix it.
I buy food! :big-grin-emoticon:
In the mean time I just want to be able to
remove the bolts in there now and make it so I can easily remove
and replace. I have a 2 keys already for the spare ignition switch.
OK, Now that the FREE FOOD is taken care of for making the switch match later
what size or type of bolts do I need to pick up? also should they be an Allen type
head I guess ?
jeff,
i did use the allen heads for the switch mounting, but only had the standard flat blade screws for the tumbler cover, it really don't matter as they are all under the black cover when your done.
i will have to go out and pull one out to get you the size info, maybe in the morning?
mike
