trankenator Posted January 27, 2010 Share #1 Posted January 27, 2010 I recently bought a 1983 venture and when I test drove it it was pretty snowy so I never had a good chance to run through all of the gears. Later on I found that It wouldn't shift into 4th or 5th gear. It's like they just aren't there. It's my first bike so I am pretty new to this. I'm hoping to have it up and running for spring time. Anyone ever have this problem? I appreciate any help Trent Link to comment Share on other sites More sharing options...
SilvrT Posted January 27, 2010 Share #2 Posted January 27, 2010 I would take a good look at the shifter linkage first ... make sure it is not binding and is adjusted properly. Link to comment Share on other sites More sharing options...
trankenator Posted January 27, 2010 Author Share #3 Posted January 27, 2010 The linkage looks good. I read somewhere about a star washer but it was pretty vague. I'm not really sure what that is. Link to comment Share on other sites More sharing options...
SilvrT Posted January 27, 2010 Share #4 Posted January 27, 2010 The linkage looks good. I read somewhere about a star washer but it was pretty vague. I'm not really sure what that is. Did you check the linkage behind the stator cover as well? Link to comment Share on other sites More sharing options...
MiCarl Posted January 27, 2010 Share #5 Posted January 27, 2010 I assume it goes to 3rd, then when you shift it stays in 3rd? If so it may be that it's dropped a dowel pin from the end of the shift drum. There have been posts about that happening. When that happens there is nothing for the shifting pawl to grab so it doesn't turn the drum. I've never been in one, but the parts fiche shows a star shaped plate that is probably there to hold the dowels in place. If it shifts to neutral then you have bigger issues. Link to comment Share on other sites More sharing options...
trankenator Posted January 27, 2010 Author Share #6 Posted January 27, 2010 Yeah when I go to shift into 4th nothing happens it just stays in 3rd gear. I've been trying to find similar posts but have been trouble finding a good description of how to fix it. Could you point me in the right direction on a good descriptive post? I might just be searching wrong but I haven't had any luck. Thanks again for your help Link to comment Share on other sites More sharing options...
Freebird Posted January 27, 2010 Share #7 Posted January 27, 2010 See if this thread helps any. It is in response to a different issue but shows the drum and pins. http://www.venturerider.org/forum/showthread.php?t=40713 Link to comment Share on other sites More sharing options...
Dano Posted January 27, 2010 Share #8 Posted January 27, 2010 That would be the correct post Don, now all he needs is the parts listed, a warm snow free garage and a couple of hours and he's good to go! Just remember Trankenator, there is a full service manual available for download in the first gen tech section also. That will describe how to remove the right side cover, the clutch and drum to be able to access the shift drum. Oh, BTW, you'll need to make up one of these to hold the clutch drum to loosen the crank bolt, some have had luck with a good impact gun to get it loose. Link to comment Share on other sites More sharing options...
SilvrT Posted January 28, 2010 Share #9 Posted January 28, 2010 Oh, BTW, you'll need to make up one of these to hold the clutch drum to loosen the crank bolt, some have had luck with a good impact gun to get it loose. ROFL ... that looks almost as bad as the one I made ... at least from looking at yours it probably took you about 1/8th the amount of time to build it! Link to comment Share on other sites More sharing options...
dingy Posted January 28, 2010 Share #10 Posted January 28, 2010 Here are a few more pictures. These are from an 83 engine. I think some of the previous pictures in this thread may be from RSV's. These pictures are with the clutch cover off, and then wiyh the clutch basket removed. Also there is a PDF attached showing the parts of an 83 transmission. Also below is a thread to the procedure to fix 2nd gear, which will point you in the direction you may need to go if it is an internal problem. http://www.venturerider.org/forum/showthread.php?t=508 Gary Link to comment Share on other sites More sharing options...
dingy Posted January 28, 2010 Share #11 Posted January 28, 2010 On ebay, search on these item #'s. 160398990829 160398990869 400099948146 It is the shifter drum, forks & linkage out of an 84. Also look at other items by this seller. He has stripped the engine all the way down. You may be able to use some of these parts. Gary Link to comment Share on other sites More sharing options...
MiCarl Posted January 28, 2010 Share #12 Posted January 28, 2010 Gary, you sure have a picture of everything! The last picture gives a pretty clear look at those six dowels. Not a huge job to get in there. If you've spit one I wouldn't use used parts. This is a problem that pops up and no use using parts that are about ready to fail. Clutch basket holder isn't necessary. Shift to 5th gear (or the highest you can) and get your assistant to apply the rear brake. That'll hold the basket for you. **EDIT** Just looked at the link Freebird provided. I'd put the assembly from a 2nd gen in there if I was fixing it. That's a no brainer. Link to comment Share on other sites More sharing options...
Dano Posted January 28, 2010 Share #13 Posted January 28, 2010 You are better off getting the upgrade part numbers as listed by Pegscraper (in the link provided by Don), if you keep putting the same parts back in,(IE the cover with the bend-over tabs), you will continue to have problems every couple of years down the road. I had this happen to me 125 miles from home one day and the stator went out at the same time. NOT a fun ride home, but she got me there! BTW, how many miles are on the bike, do you know if the "second gear" issue has been fixed? (actually it's the thrust and wear washer on the end of the middle gear shaft that causes the problem, second gear is the symptom) Once you get it running, get on the throttle in 2nd gear, if it jumps, you're due for the repair. Not for the faint of heart, but can be done by someone with mechanical training and not afraid to pull the motor out of the bike. Good luck, and we'll help you all we can! Dan Link to comment Share on other sites More sharing options...
trankenator Posted January 28, 2010 Author Share #14 Posted January 28, 2010 Hey thank you everyone! You guys have been amazingly helpful. I'm going to start work on it tomorrow. It's 42000 miles on it and the second gear seems pretty strong! Hopefully it stays that way. I just picked up my caliper rebuild kit today so I'm going to put that all together tomorrow as well. After all that it should be ready for a good ride! Thanks again I am very very thankful Link to comment Share on other sites More sharing options...
warthogcrewchief Posted January 28, 2010 Share #15 Posted January 28, 2010 Looks like you're going on the right direction. Although, something to think about: I thought about rebuilding my calipers before I saw the rebuilt R1 Calipers SkyDoc sells on here. I'm looking to get the R1 calipers for my '89 because the housing is one piece instead of two pieces bolted together (less give = better braking ability). Link to comment Share on other sites More sharing options...
Condor Posted January 28, 2010 Share #16 Posted January 28, 2010 Thanks for the info and the posts guys. The '83 has been getting clunky lately. Looks like I have another project..... Does it ever end??? Link to comment Share on other sites More sharing options...
dingy Posted January 28, 2010 Share #17 Posted January 28, 2010 Looks like you're going on the right direction. Although, something to think about: I thought about rebuilding my calipers before I saw the rebuilt R1 Calipers SkyDoc sells on here. I'm looking to get the R1 calipers for my '89 because the housing is one piece instead of two pieces bolted together (less give = better braking ability). Not quite as simple as replacing the calipers on the MKI's (83-85) We have to replace forks, rotors & calipers. The R1 calipers have a 100mm bolt pattern at fork mounting point. The originals have an 80mm bolt pattern. Rotors are different diameter as well. Gary Link to comment Share on other sites More sharing options...
Condor Posted January 28, 2010 Share #18 Posted January 28, 2010 Not quite as simple as replacing the calipers on the MKI's (83-85) We have to replace forks, rotors & calipers. The R1 calipers have a 100mm bolt pattern at fork mounting point. The originals have an 80mm bolt pattern. Rotors are different diameter as well. Gary Not on the MKII's Gary. The R1's are plug and play.... Link to comment Share on other sites More sharing options...
dingy Posted January 28, 2010 Share #19 Posted January 28, 2010 Not on the MKII's Gary. The R1's are plug and play.... I didn't mention MKII's OP has an 83, MKI. Gary Link to comment Share on other sites More sharing options...
Condor Posted January 28, 2010 Share #20 Posted January 28, 2010 I didn't mention MKII's OP has an 83, MKI. Gary I donno?? I was just going by the quote you attached to your post from warthogcrewchief. He has an '89, and was the one mentioning the R1's from Earl... Sorry for the misunderstanding.... Link to comment Share on other sites More sharing options...
MiCarl Posted January 28, 2010 Share #21 Posted January 28, 2010 Not quite as simple as replacing the calipers on the MKI's (83-85) We have to replace forks, rotors & calipers. The R1 calipers have a 100mm bolt pattern at fork mounting point. The originals have an 80mm bolt pattern. Rotors are different diameter as well. Gary Link to comment Share on other sites More sharing options...
Condor Posted January 28, 2010 Share #22 Posted January 28, 2010 Link to comment Share on other sites More sharing options...
Dano Posted January 28, 2010 Share #23 Posted January 28, 2010 yep, there's another thread headed south towards Mexico............ Link to comment Share on other sites More sharing options...
MiCarl Posted January 28, 2010 Share #24 Posted January 28, 2010 yep, there's another thread headed south towards Mexico............ Naw, we'll just go Link to comment Share on other sites More sharing options...
Dano Posted January 28, 2010 Share #25 Posted January 28, 2010 Pick me up on your way down I69, would 'ya? Link to comment Share on other sites More sharing options...
