RandyR Posted May 5, 2010 Share #26 Posted May 5, 2010 Is there an on-line web page for the Smith's gauges? I looked and couldn't find a catalog. Smiths are what my 900cc Triumph uses, but I can't find a general catalog of their gauges. Link to comment Share on other sites More sharing options...
Yamaman Posted May 5, 2010 Share #27 Posted May 5, 2010 Is there an on-line web page for the Smith's gauges? I looked and couldn't find a catalog. Smiths are what my 900cc Triumph uses, but I can't find a general catalog of their gauges. Try this site: http://www.gaugeguys.com/Smiths/smithsindex.htm Click on "Classic Guages" to find the one from above. They're kinda pricey. Over $170 for the dual oil/water temp guage. Link to comment Share on other sites More sharing options...
Ponch Posted May 5, 2010 Share #28 Posted May 5, 2010 http://www.gaugeguys.com/Smiths/magnolia.htm http://www.gaugeguys.com/images/Magnolia_dual_master.jpg Link to comment Share on other sites More sharing options...
Ponch Posted May 5, 2010 Share #29 Posted May 5, 2010 No room 2" or larger gauges plus a tach. Can possibly do (2) 1 1/2" plus (1) 2 1/16" gauge, but it will be tight. Link to comment Share on other sites More sharing options...
RandyR Posted May 5, 2010 Share #30 Posted May 5, 2010 No room 2" or larger gauges plus a tach. Can possibly do (2) 1 1/2" plus (1) 2 1/16" gauge, but it will be tight. ok, I can wait. The Drag Spec tach with 2x 1.5in gauges looks ok. Will wait to talk at MD with you about options. Link to comment Share on other sites More sharing options...
Yamaman Posted May 5, 2010 Share #31 Posted May 5, 2010 No room 2" or larger gauges plus a tach. Can possibly do (2) 1 1/2" plus (1) 2 1/16" gauge, but it will be tight. Darn! Oh well, those Smith gauges were too expensive anyway! Link to comment Share on other sites More sharing options...
Ponch Posted May 6, 2010 Share #32 Posted May 6, 2010 I can do (2) 2 1/16" gauges or (1) 2 1/16" gauge plus (1) 1 7/8" tach in the original configuration plate. That way you could have 2 gauges in one (the Smith dual gauge) plus the tach. Link to comment Share on other sites More sharing options...
RandyR Posted May 6, 2010 Share #33 Posted May 6, 2010 These seem pricey, but multi-function. Maybe cheaper if they could be bought without the housings? http://www.dakotadigital.com/index.cfm/page/ptype=results/category_id=60/home_id=60/mode=cat/cat60.htm Link to comment Share on other sites More sharing options...
RandyR Posted May 6, 2010 Share #34 Posted May 6, 2010 http://www.denniskirk.com/denniskirk/b2c/product_images/2/2/1/600pix/22110084.jpg Highly visible LCD display shows RPM and dual temps Large digital tachometer display with programmable REV bar graph is easy to read at high speeds Both temp meters feature programmable high-temp warning lights; temp range: 32-482 degree F or 0-250 degree C Keeps record of max RPM and temp Also shows voltage, time, programmable shift light and optional air/fuel ratio meter Measures 3 3/8 in. W x 1 1/4 in. H x 3/4 in. D Includes water temperature sensor; optional EGT sensors, oil temperature sensors and cylinder head temperature sensors available separately Included Items: (1) Meter (1) Power wire (1) RPM wire set (2) Temp sensor wire set (2) Water temp sensor (3) Mid-way connect (1) Velcro (1) Battery http://www.denniskirk.com/jsp/product_catalog/Product.jsp?skuId=408505&store=Main&catId=&productId=p408505&leafCatId=&mmyId= This is a surface mount package for snowmobiles available at DennisKirk. but a super combo gauge with Tachometer, oil temp, water temp, and voltage in a size that would fit. I'm sure its adaptable. Maybe someone else has it already for a motorcycle double fire ignition. I'll search around. Link to comment Share on other sites More sharing options...
Ponch Posted May 6, 2010 Share #35 Posted May 6, 2010 Randy, I can make you a blank plate and laminate it or you can paint it if you want. Link to comment Share on other sites More sharing options...
RandyR Posted May 6, 2010 Share #36 Posted May 6, 2010 Randy, I can make you a blank plate and laminate it or you can paint it if you want. Ponch. Thanks for doing all this for us. Lots of options it would appear. Well, I'm packing for a three day weekend in Jacksonville for the M&E there. I'll eat some fish & crabs, drink a few brew, and discuss the possibilities with the other VR riders there.. Link to comment Share on other sites More sharing options...
rowdy7 Posted October 9, 2010 Share #37 Posted October 9, 2010 I'm not sure where the best place to post this is but this looks like as good a place as any. I hope I have attached pictures of Ponch's guage on my 07 RSV so you can see what they look like. I got the primered metal plate and painted it to match the 07 blue then Ponch came over and basically installed them with me as gofer. Many many thanks for that, Ponch. And did I mention that he rode over in the rain to do it. It is so nice to have something useful (to me) in that slot and to be able to see what your engine is doing. Thanks again Ponch. If someone needs a slightly used cassette player, I have one for shipping cost. Link to comment Share on other sites More sharing options...
Sleeperhawk Posted October 9, 2010 Share #38 Posted October 9, 2010 I'm not sure where the best place to post this is but this looks like as good a place as any. I hope I have attached pictures of Ponch's guage on my 07 RSV so you can see what they look like. I got the primered metal plate and painted it to match the 07 blue then Ponch came over and basically installed them with me as gofer. Many many thanks for that, Ponch. And did I mention that he rode over in the rain to do it. It is so nice to have something useful (to me) in that slot and to be able to see what your engine is doing. Thanks again Ponch. If someone needs a slightly used cassette player, I have one for shipping cost. Nice looking setup. Beats the cassette player Link to comment Share on other sites More sharing options...
Sideoftheroad Posted October 11, 2010 Author Share #39 Posted October 11, 2010 Rowdy, Which tach is that? Link to comment Share on other sites More sharing options...
Ponch Posted October 11, 2010 Share #40 Posted October 11, 2010 Rowdy, Which tach is that? Nova MMB Micro Mini Tachometer http://bikergarage101.com/85025novammbmicrominitachometer.aspx Link to comment Share on other sites More sharing options...
Owen Posted October 11, 2010 Share #41 Posted October 11, 2010 Ponch, I'm wondering about bar risers. Do they cause any problems with fitment? Link to comment Share on other sites More sharing options...
rowdy7 Posted October 11, 2010 Share #42 Posted October 11, 2010 Ponch, I'm wondering about bar risers. Do they cause any problems with fitment? I am at work and can't remember if they are 1" or 1.5" but I have risers on mine and you can see there is no problem with fitting. I was concerned about the same thing but Ponch said no problem and was right. I had a better picture at home but I am not there:doh: Link to comment Share on other sites More sharing options...
Ponch Posted October 12, 2010 Share #43 Posted October 12, 2010 Ponch, I'm wondering about bar risers. Do they cause any problems with fitment? No Problem. Link to comment Share on other sites More sharing options...
fw2000 Posted October 13, 2010 Share #44 Posted October 13, 2010 Recently had my 06 RSV triked. Need rpm range so I know where I am when riding. Trike rear end seems to have slightly altered my gearing. 5th(OD) seems to really bog down under 70. Runs good in 4th but don't have a clue what my engine is turning. Need to know where power band is and what redline is:bang head: Link to comment Share on other sites More sharing options...
Ponch Posted October 13, 2010 Share #45 Posted October 13, 2010 Ventures love higher rpm's. The redline on a stock G2 is about 6500. The Dyna 3000 ignition will push the redline to 8k. Link to comment Share on other sites More sharing options...
kj5ix Posted October 13, 2010 Share #46 Posted October 13, 2010 Recently had my 06 RSV triked. Need rpm range so I know where I am when riding. Trike rear end seems to have slightly altered my gearing. 5th(OD) seems to really bog down under 70. Runs good in 4th but don't have a clue what my engine is turning. Need to know where power band is and what redline is:bang head: I am finding the same thing here ( new to RSV Trike ) pulling the camper in 5th is a killer on gas I have found this next trip will try to stay in 4th as much as possible. My normal cruse speed is 65 I got as low as 19 MPG last trip..... Good thing I have the extra tank. Link to comment Share on other sites More sharing options...
Ponch Posted October 13, 2010 Share #47 Posted October 13, 2010 Hay George, I been working on something you might like. Should look pretty good with your wood grain stuff. http://i672.photobucket.com/albums/vv87/dawarren77377/Gauges/BrownTortoiseShell.jpg?t=1286983794 Link to comment Share on other sites More sharing options...
kj5ix Posted October 13, 2010 Share #48 Posted October 13, 2010 OH Crap, Dave your killin me,,,,, Does the offer to come and help still stand, and do you know how to sync carbs,, :rotf:I have a brand new carbtune, never opened,,, and not a clue ( for the moment, been too busy riding ya see,, ) OH I can see what little i have saved for ridding going out the window now :) Link to comment Share on other sites More sharing options...
Ponch Posted October 13, 2010 Share #49 Posted October 13, 2010 You betcha, offer still stands. I never did a carb tune, but I bet ol' Squid can teach me, or Goose might even come along and teach both of us. Ponch Link to comment Share on other sites More sharing options...
kj5ix Posted October 13, 2010 Share #50 Posted October 13, 2010 You betcha, offer still stands. I never did a carb tune, but I bet ol' Squid can teach me, or Goose might even come along and teach both of us. Ponch I almost smell a party coming on,,,,, I will be busy this next week, with building one, and the Colors Rally in Ark, and Dr apt the 26th in Dallas We may have to set something up and make a happening out of it,,, Link to comment Share on other sites More sharing options...
