Almost 80 degrees today...wanted to take the bike for a spin. It wasn't handling properly...thought perhaps tire pressure. Sure enough it was low...while adding air realized that the valve stem was rotted and broken. The bike is only two and 1/2 yrs old...this surprises me.
Anyway, I need to get it repaired...I am not much of a mechanic and I am wondering how difficult it is to remove the front wheel. Appreciate any advice.
:95: :confused24: :think: :o
Not a problem, just jack it up, remove front fender, remove brakes, remove front wheel, pay atten. as to what spacer goes on what side, they look the same to me, but was told to watch that..Good luck, really not hard to do, if you have a lift.
Piece of cake...
undo and remove the brake calipers (the mounting bolts, not the "slider" bolts)
hang them off to the side a bit
undo the axle and slide it out, holding the wheel as you do
drop the wheel
oh yeah.... jack the scoot up first LOL
this is correct, I couldn`t get mine high enough and had to pull the fender....
  SilvrT said:
Piece of cake...
undo the pinch bolt underneath the right fork
drop the wheel
not required... unless you can't "get it up" high enuf...
  Kbay said:
pay atten. as to what spacer goes on what side, .
They are called "collars" and have the same part number so they should be the same.
Jim,
here are the specs that you wanted. be safe
mike
pretty danged brave!! asking for help and posting those high temps on the same page!!
where's my gun?:snow2:
frt axle torque 58 ft lbs
frt axle allen bolt 14 ft lbs
  1 Canuck said:
Bring it over to my place and I'll do it for you. Must bring the weather with you.
:rotfl:
dag nabbit!! why didn't i think of that??:bang head:
Hey Jim,
Wouldn't this be covered under the warranty? Do you have a decent dealer in your area that would pull the front wheel and put a new valve stem in?:confused24:
Just a thought,
Earl
  skydoc_17 said:
Hey Jim,
Just a thought,
Earl
Earl is SPOT ON! I would expect the Valve Stem NOT to dry rot prior to tire needing replacement due to tread-wear. Next question is how good your dealer is?
Let us know??
I doubt a 2.5 year old valve stem is going to covered under warranty.
When you have it changed out, have them install metal valve stems. Much more durable then rubber ones.
Thank all of you for your replies...got the wheel off and will take it tomorrow for repair. Special thanks to Mike (eusa1) for the phone call and advice. A couple of you asked about taking it to the dealer. I have a great dealer, that would probably do the repair without any problem...only thing is my dealer is 90 miles away...so I will just take care of this one. You all are super!
I read somewheres there was a bad batch of valve stems from china. Recall except there is no way to find out which vehicles they are on. No way to trace them, no serial numbers etc. The dealer should replace them for you. I have replaced valve stems without removing the wheel or tire. Jack the bike up. Mark the tire - rim location. Let the air out of the tire and collapse bead. Use a stem puller to remove the old stem. While holding the bead collapsed pull the new stem in with the puller. Re inflate the tire while making sure your marks are aligned.
Mike
Will do...with a 90 degree bend.
Tire has been removed, repaired, and reinstalled. :banana:No big deal! :sign kewl:Thanks for your information and encouragement. :thumbsup2:This little exercise has given me confidence for the next tasking...splitting the faring and installing the wiring for the GPS and the Buddy Rich cable.:dancefool::clap2:
Glad you got it taken care of...
however..... your still in deap shirt over the wize cracks about the the great weather down there!!:snow2::mad:
now does anyone remember where to get the passing lamp spacer for jim, before he tackels the next project?:confused07:
