Guest johnny sidecar Posted October 3, 2007 #1 Posted October 3, 2007 first time posting thread. I have an 03 midnight venture with sidecar looking for car tire for rear. any hints
AZSpyder Posted October 3, 2007 #2 Posted October 3, 2007 There is a thread going on now. Check out: http://www.venturerider.org/forum/showthread.php?t=14762 By the way, there is a rule here that you need to post pictures. I personally would love to see one of a side car on a Venture. Jerry
1rooster Posted October 3, 2007 #3 Posted October 3, 2007 first time posting thread. I have an 03 midnight venture with sidecar looking for car tire for rear. any hints I have a sidecar on my 99 and putting a 165SR15 on it.It's the same height and width as the 150/90/15 on the bike now.I took a used tire and mounted it on a VW wheel and it fit perfect so in my assumption the 165 will fit on the MC wheel.Could be mistaken but gonna try it.I love the sidecar.i have the Velorex.Which one do you have?
Pyro Posted October 4, 2007 #4 Posted October 4, 2007 You giys thoughtmy 99 tire was bald earlier this year. But BOY does the hack wear them out fast! My 89 w/ Hannagan Astro 2+2 wore the tires out in 8k or less.
Tartan Terror Posted October 4, 2007 #5 Posted October 4, 2007 you are gonna have a problem there. First let me say I own a tire business and I do not recommend doint that. Car and bike tires are very different. You most likely need to use a radial tire and it will feel very different and I dont recommend mixing radial and bias on a bike. secont problem is that you have a 15" wheel in the rear. Only thing I can think of that may still be around is a 165R-15 tire. Those fit the old VWs. Everything else will be too wide. The choices of tires in 15" is deminishing as all the cars are using wider 15s on compacts and all others are using 16" wheels and up. I say again that I strongly suggest using a bike tire unless you are doing a trike. In this case Bike tire all the way!!!
